If I want to create a pipelined flip-flop (FF) structure, where data from the input is at the output after 2 clock cycles. This is a top-down blocking assignment code.
module circuit (
    input wire clk,
    input wire rstn,
    input wire [7:0] din,
    output reg [7:0] dout
    reg [7:0] mid;
    always @ (posedge clk) begin
        if (!rstn) begin
            mid  = 0;
            dout = 0;
        end else begin
            mid  = din;
            dout = mid;
        end
    end
endmodule
Schematic for this code:
If I use blocking assignment in reversed order:
module circuit (
    input wire clk,
    input wire rstn,
    reg [7:0] mid;
    always @(posedge clk) begin
        if (!rstn) begin
            mid  = 0;
            dout = 0;
        end else begin
            mid <= din;
            dout <= mid;
            dout = mid;
            mid = din;
        end
    end
endmodule
Then I get a schematic like this, which is identical to what would I get if I were to use non-blocking assignments.
If I keep the ordering in mind, can I use the blocking assignments to get the behavior from the circuit for which I usually use the NBA? For example, avoiding race conditions, sampling asynchronous input, etc.?
The best approach is to follow the advice in the paper:
Guideline: Use nonblocking assignments in always blocks that are written to generate sequential logic
Then you never need to worry about race conditions or other unexpected simulation/synthesis issues. For sequential logic, use this, for example:
    if (!rstn) begin
        mid  <= 0;
        dout <= 0;
    end else begin
        mid  <= din;
        dout <= mid;
    end
end
