Here is my circuit
circuit
Here is output of measurements:
va
I cannot understand why there is no current in negative direction. Current keeps flowing in positive direction when there is negative voltage.
  • \$\begingroup\$ Because you have grounded it...? \$\endgroup\$
    – KristoferA
    Commented Oct 16, 2023 at 14:56
    \$\begingroup\$ You have a current flowing during the negative half-period. And the current is positive because of the way (the direction) you have connected the "green" ammeter. \$\endgroup\$
    – G36
  • \$\begingroup\$ Do you mean no current flowing in negative direction or no current in negative direction of the voltage ? \$\endgroup\$
    – MiNiMe
    Commented Oct 16, 2023 at 15:01
You have set both of your current probes to align with the diodes, rather than pointing to gnd. As a result both currents appear to be positive.
If you change PR1 to point towards gnd, you will get the behaviour you are expecting.
