I'm trying to incorporate a ceramic chip antenna in a wearable device due to its low footprint and affordability. After reading the datasheet countless times and YouTube tutorials I'm still not 100% sure on how to make the perfect feedline.
I have used various impedance calculators and obtained the required values for track width and GND clearance, for a co-planar waveguide (this type of "trace" is suggested by the datasheet). My questions are:
Where does the RF feedline start at? The datasheet says it needs to have 50 Ohm. Does the impedance start counting right after the RF front-end pad up to the ceramic chip or from the pi-network circuit to the chip?
If the feedline comes from the RF front-end through a thin pad then a thin track is needed to connect to the thin pad. In this case, it will be way thinner than the feedline I computed. Through this approach, I obtained a track with at first 0.2mm (7.9 mil) and then it increases its width up to 1.06mm (41.7 mil; as computed for the 50 Ohm impedance). I'm not sure about this because I assume the thin portion has way higher impedance than the thicker portion that was computed for 50 Ohm. Won't this wdith transition add up (like resistors in series) to the overall feedline resistance?
If the previous point is true, I had the idea of, instead, computing the feedline parameters by fixing the variables Impedance = 50 Ohm and Track Width = 0.2 mm (so has to prevent width changes), but then it results in a required clearance of 0.07 mm (2.8 mil) which seems to be too low for most manufacturer.
How would you explain / solve this? Should I just go with my current design and hope it works?
Thanks!!
EDIT:
After checking everything mentioned, I would just like to know if the transition to the "antenna region" will be problematic (i.e. will it lead to wave reflections?) on the last picture.
Updated feedline parameters:
Width transition from RF front end to antenna feedline (way better now):
Width transition from antenna feedline to "antenna region" (it still feels like a big transition, so this is where I'm not sure whether it's OK):
Antenna's datasheet (they also seem to have a non-negligible width transition):
