There is a way to do this, but it is probably (hopefully?) well beyond the scope of what you were asked to do. I agree with comments that it was probably a miscommunication.
They also might've meant a universal motor, which as the name suggests, can be run on DC, but isn't exclusive to DC. These are common targets for AC speed control, as their speed is poorly regulated otherwise. Handheld high-speed rotary tools are a classic example of this design: both the series-wound / universal motor, and the thyristor-based speed control.
Anyway, I won't go into detail of a complete DC control scheme, just drop the hint that it is possible to use SCRs on DC. The key is finding some way to force an SCR to turn off.
In this example:
Source: my website, https://www.seventransistorlabs.com/Images/SCR_Inverter.png
A series pair of SCRs fire alternately, connected to the load. The load is wired between Output and GND, and the supplies are bipolar (in this test it was just ±17V from a bench supply). This is an AC output; but it is supplied by DC, so it accomplishes the key step of turning off SCRs alternately.
The key is the 9µH + 0.47µF series resonant circuit: when one SCR turns on, the other one is still on, so together they short out the supply. The power source is delayed from absolute shorting-out by the series inductance (the 2 x 160µH), and when this resonant circuit goes from ~nominal supply voltage to suddenly a short circuit (a step voltage change across its terminals), it resonates, current rising to a peak, then reversing, and when this reverse current exceeds the load current, and stays reversed for longer than tq, the SCRs turn off (both of them!) and the MUR2020 is left holding the resonant current. After completing one full cycle, that diode turns off as well, and voltage returns to nominal supply. (We could turn off completely at this point, and some clamping would be needed to absorb flyback from the 160µH, and then we'd be done.) To switch on again, gate drive is maintained to one side, and thus load current flows, in this case alternately.
Thus, we have a half-bridge inverter circuit, with shorting-mode commutation. Ordinarily, such as with MOSFETs and IGBTs, we prevent shoot-through by leaving dead time between the gate drive signals. But SCRs are, in some respects, the inverse of those components, and we can harness their latching ability with appropriate circuit design (the inductor and resonant circuit), and thus we actually use shoot-through to our advantage.
The left-side circuitry is just to make a variable time delay between the two gate triggers, so that PWM output can be generated -- the output here actually has a mean DC component, so can in fact drive a DC motor, in this case it would be reversible even (as PWM is variable above and below 50%). Additional clamp diodes would be needed to handle regenerative current (and the inductive load) of a real motor, among various other improvements; this was just a test circuit I made years ago, far from a practical, reliable circuit.
