Many 32768 Hz. crystals have a similar construction to a tuning fork...its two tines move in a similar way. And like a tuning fork, constant pressure (as DC voltage would supply) does not excite the resonant vibrations of tine movement. Constant pressure might move the tines to a new position, but when slowly released, the tines simply move slowly back.
A very quick "rap" pulse does excite resonant tine movement, which rings like a bell, and slowly dies away much later. A quick pulse of voltage would do the same to a crystal resonator, via its piezoelectric property.
An oscillator excites the 32768 Hz crystal regularly: since it provides a pulse every cycle, very little pulse power is needed to keep it vibrating. The oscillator works by sensing tine motion, and providing pulse power to reinforce tine motion.
These oscillators sense tine motion by using the quartz piezoelectric property to convert mechanical motion to electrical voltage. The oscillator boosts the sensed voltage and then feeds back enough power (microwatts) to keep oscillations going.
The oscillator circuit is powered by a DC source. It is the oscillator's job to extract some power from this DC source to provide AC power at the crystal's resonant frequency (32768 Hz) to keep it going.
The electromagnet you might find inside a watch or clock provides a means of advancing the clock's hands each second.
