I have a two DC motors with smd reel mounted on the 1st one and an empty reel on 2nd one. What I want to happen is that my operation will composed of two halves: 1st half: The 1st DC motor is off or "disenganged". What I mean is, the 2nd DC motor will be pulling the SMD reel off the 1st DC motor, but only the 2nd DC motor is driven. I just want to 1st DC motor to freely rotate as the 2nd motor pulls the reel off it.
2nd half: The 2nd DC motor now contains the components. I want the "roll back" the SMD components back to original reel. I will now drive the 1st motor and I want to turn off the 2nd motor or "disengage" it such that it will be free to move.
I currently have the part: HG16-240-AB-00 and it seems to offer so much resistance when I try to manually rotate it while it's off. This motor is DC brushless geared (1:240 ratio).
- Can anyone point me to what type of DC motor should I be searching given this requirement? Brushless? Brushed with less gear ratio? Stepper?
- Is the reason my motor so hard to turn while it's off is because off high gear ratio?
