I've recently been looking into the width of vias, and could use the feedback of more experienced designers.
Through-hole vias :
I've read that for through-hole vias, the way to go is 8:1 (so if your PCB is 1.6mm thick, then the ideal via will be 0.2mm wide).
From that point on, would there be any reason for me to use a different width ? If i were to use a 0.4mm via (4:1 aspect ratio), would that impact the reliability of my PCB ?
I've seen a lot of PCBs with vias much wider than that, and now don't really understand why. I used to naively think they'd be able to handle more current, but that's only up to the thickness of plated copper going down the barrel right ?
Going a bit further, with microvias and blind vias
I've been able to read a bit about microvias. To sum it up, they're at most 0.25mm deep, and the ideal aspect ratio is somewhere around 0.8:1 (so wider than deeper). My first question is, are aspect ratio calculated from the drilling size, or finished hole ? I've read contradictory opinions on the matter, and at such small numbers, the 35µ of copper start to matter.
Secondly, I've been able to read enough things about microvias, but blind vias seem to be overshadowed by their smaller brother. From what I've understood they're manufactured similarly to through-hole vias. As such, should their aspect ratio be calculated from the same 8:1 ratio ?
With all that being said (or asked), would defining my stack-up and calculating my via widths once from that be best practice ? As such, should all my TH vias be the same width ? No matter if they're stitching, high current, high speed or anything else ?
If you have any wisdom to share regarding via width/failure or aspect ratio, I'd be happy to read it.
