I am looking for a battery charger for AA batteries, without taking out the batteries from the board.
The board which is powered by AA batteries is : http://www.tagsense.com/images/stories/products/activetags/ZT-500-datasheet-short-form.pdf
I dont have any idea if I can charge the batteries just by employing the Vcc and Gnd pins I have on the board.
When the batteries are plugged into the board the total voltage at Vcc and Gnd pins is : 3V.
Could any one suggest for a battery charger which can charge the batteries without removing them from the board ..?? I am ready to build the circuit and if I can find already available charger it will be good.
Thanks,
  • \$\begingroup\$ If you use NiMH batteries (of course, they are rechargeable), but with 1.V terminal voltage (not 1.5V for alkaline batteries), you might be able to leverage this. PS> No personal experience with that circuit. \$\endgroup\$ – icarus74 May 9 '13 at 6:05
The data sheet you link to says (on page 6) that the battery is CR123 (not AA), which is a non-rechargeable lithium battery.
  • \$\begingroup\$ Yes I think there should be some error in the datasheet, but the Tag what I am using has 2 AA batteries \$\endgroup\$ – Sandesh May 9 '13 at 15:37
protected by W5VO May 9 '13 at 18:48
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
