I am trying to understand how to design an inductor that has constant parameters over a wide range of frequencies. Especially over high frequencies because I want to use them for impulse testing which have a characteristic frequency around up to 100kHz.
  • What exactly makes the inductance of a real inductor change at diferent frequencies?
  • What is the effect of the core in this dependency? (With or without iron core, for example.)
  • What has to be considered in the design to minimize the skin effect so as to have a low ESR?
Additional info:
To illustrate this, I have five different inductors for which I have performed Ls and Rs measurements on an Agilent E4980A RLC meter:
All of these inductors have a decently constant Ls value from 50 Hz to 300kHz, but their ESR behavior differs.
  • \$\begingroup\$ Why is inductor #2's inductance at 300 kHz in volts? Are you sure you were always measuring series resistance? \$\endgroup\$
    Commented Oct 30, 2023 at 13:06
  • \$\begingroup\$ @Andyaka My bad, that is supposed to be μH instead V. But yeah pretty sure I was measuring Ls and Rs since those are the output values of the LCR meter \$\endgroup\$ Commented Oct 30, 2023 at 14:37
  • \$\begingroup\$ Wide band inductors might look a little like this. \$\endgroup\$ Commented Oct 30, 2023 at 22:07
  • \$\begingroup\$ @periblepsis Do you have any idea on why this design is helpfull for wide-band applications? Thank you though! \$\endgroup\$ Commented Oct 31, 2023 at 12:09
  • \$\begingroup\$ @SantiOspina You may want to start by reading "Radiation Field of a Conical Helix", by J. S. Chatterjee. And then read his paper called "A Wide-Band Oscillator Using a Conical-Helix Tuning Inductor", published the following year. \$\endgroup\$ Commented Oct 31, 2023 at 21:46
