I'm trying to troubleshoot an old analog oscilloscope (Metrix ITT instruments OX 725), which seems to come from the late 1980s in France.
There is (part of?) a service manual with circuits diagrams available online (https://archives.doctsf.com/documents/afficher_document.php?num_doc=100437&num_fic=1), but I'm having a hard time piecing together how the circuits are actually connected.
In particular, there seem to be three different symbols used for 'this part connects to a different circuit' that I can't identify. Does anyone know what they mean and what the difference between them is?
Pill-shaped:
These are the most common ones.
Pill shaped symbol
Flag-shaped:.
These kind of look like arrows. Most of them (but not all) have markings like +12A or -12V and point according to the sign of the number, so maybe they indicate connections to the power supply and some are misprinted?
Double-angled-bracket-shaped:.
These look similar to modern connector symbols, but not quite the same.
As an example, here is one of the schematics containing all three kinds of symbols: enter image description here
A different opinion from Voltage Spike's...
Pill shaped - These are more likely connector pins. Note the J#/Pin# format, as in J5 10.
Flag shaped - I agree that these are power connections. I don't think the arrow indicates current flow, but rather source/destination (which may be the same a current flow, I guess).
Double-angled-bracket-shaped (double arrow heads?) - I think these are off-page connectors, for a multi-page schematic.
My guesses:
Pill shaped - These are probably solder jumpers or resistor jumpers, or even 0.1" header jumpers.
Flag shaped - defiantly VCC/powerrail markers. The arrows could indicate direction of current flow
Double-angled-bracket-shaped - Not sure either, would need to see more, probably a test point or a different kind of power rail, maybe high voltage. Could even be comm
    \$\begingroup\$ Double arrow ones may indicate that the signal moves to another sheet. All of them in the example schematic have diamond with a reference number next to them (e.g. <F3>, with the current sheet being <F2> according to the bottom left. Maybe they use >> for signals and => for power. \$\endgroup\$ Commented Nov 4, 2023 at 0:09
