My receiver has the following system architecture:
I know about the parts rules but I want to be specific because I am confused. I am using the AD831 as mixers, AD8367 as IF amplifier and LM386 as audio amp. Old, tried and trusted parts, no surprises with exception to impedance.
Input BPF has Z=50 ohm, mixers also have Z=50Ω, IFBPF is a 100 Ω, IFVGA is Zi=Zout=200 Ω. I don't understand what is Z for LM386 but I will assume it is a lot because input resistance claimed to be 50 k.
The maximum voltage gain of LM386 is 46 dB. The voltage gain makes me confused because normally we deal with the power.
If we take these 46 dB and try to simulate signal chain we get the following results:
44 dBm and more seems to be crazy.
I do understand this is a voltage gain but what to use as a reference point? 50 kΩ?
For example, if we have -1.5 dBm at 50Ω then Vp-p = 0.266 V.
If we look at Vp-p=0.266 V with 50 kΩ input resistance then we have -31.5 dBm @ 50 kΩ.
46 dB is a gain of 200 times. So, 0.266*200 = 53.2 V @ 50 kΩ which is an impossible number for LM386. And none of audio amps is loaded with 50 kΩ output. Not even a valve PAs.
So this all makes me think that I should consider mixer output load and audio amp input to be taken as 2 parallel resistors so its common resistance is pretty much the same 50Ω.
If we do that we should use Vp-p = 0.266 V converted to -31.5 dBm @ 50 kΩ and amplified by 46 dB gain which I presume becomes 14.5 dBm at 4 Ω if we use 4Ω speaker and the amp magically transforms the impedance. This is 28 mW of electrical power.
Now, I tried to read about speaker sound pressure level and relation of this to the power of the amplifier. I figured that 1 W at 1 meter distance produces about 90 dB SPL. This is equal to a very noisy street.
If we look at 1W/28 mW = 36 which is about 31 dB. 90 dB SPL - 31 dB = 59 dB SPL which is quiet conversation.
This sounds a bit strange to me.
I believe that I missed something important and I would appreciate someone to correct my train of thought.
