There is a demand for a delivery of 3 A through several layers using vias.
Presented below in the picture is my PCB manufacturer's abilities regarding vias.
A single via can withstand 1.4 A. Are there any strategies regarding how to deliver this current, maybe through several vias in parallel?
The displayed via current is not a maximum, but rather a recommendation to keep the temperature under control. A rise of 20° to 30° in temperature is usally fine, but it depends on your application.
If you have the space to integrate multiple vias in parallel, go for it.
I would suggest going with conservative values of 500mA per via for a 10° rise or using even bigger vias if your manufacture allows it.
Here is a tool for calculating temperature depending on via parameters.
  • \$\begingroup\$ Hello, i have a pulse of 50u seconds and 35% duty cycle ,is there a way you could recommend me to know by how much the temperature will rise after 17.5 seconds? \$\endgroup\$
    – rocko445
    Commented Nov 7, 2023 at 19:30
