I got some answers here, but as @SamGibson pointed out, I opened this thread so that the question does not turn into a "chameleon question".
First of all, let me state everything exactly. This circuit is a commercially available AC Main line voltage meter module, commonly known as an Arduino module.
This circuit is manufactured to be (Input: 50 Hz / 80-220V, Output: 0-3.5V).
- What is the purpose of capacitors C2 and C5 considering the measurement purpose, measurement voltage and frequency? What could they be used for in this circuit? Could it be something like an integrator? It doesn't make sense to have a low pass filter because no signal other than 50Hz will enter anyway.
- Why is capacitor C1 there? I thought there was no offset on the AC voltage line?
- Why is the lower leg of R1 connected to the middle of R2 and R3? What is the purpose here?
- Is this a voltage transformer or a current transformer? What is the difference and how can you tell by looking at this circuit? We also talked to @Andyaka in the previous question. He stated that this small transformer is not suitable. And he is right because there is not even a proper datasheet. I wonder what you think about this issue, is it too much of a problem. Is there another 1:1 current transformer that can be used instead?
- When determining the R1 value, which data in the datasheet is used for the heating state of the transformer and with which formulas is it calculated?
I look forward to your answers.
