If I have code like this:
logic [15:0] arr [0:3];
assign arr = {'d0, 'd1, 'd2, 'd3};
reg [1:0] k;
reg [63:0] out;
always @ (posedge clk) begin
    out <= {{16'd0}, {arr[k]},
            {arr[k+1]}, {arr[k+2]};
    k   <= k+2;
end
Is this valid syntax and will it synthesize into a multiported ROM?
It's valid syntax for SystemVerilog, but not synthesizable. I'm assuming k gets a value from some code you have not shown. Then you cannot assign it inside the always block as shown.
And you probably should define arr as a parameter, not as a variable
parameter logic [15:0] arr [0:3] = {'d0, 'd1, 'd2, 'd3};
It probably won't synthesize to a ROM. More likely a mux that gets optimized with constant inputs.
  • \$\begingroup\$ If I use the way you have shown it, is it synthesizable? I'm using k here as an index and it gets updated based on some conditions. And can I use out <= {arr[k+3]}; with the syntax that you specified? Is it synthesizable? \$\endgroup\$
    – lousycoder
    Commented Nov 6, 2023 at 19:25
    \$\begingroup\$ You can only update k or any variable from one process to be synthesiable. Why are you assigning it to 0? \$\endgroup\$
    – dave_59
    Commented Nov 6, 2023 at 20:12
  • \$\begingroup\$ Have updated the code in the question \$\endgroup\$
    – lousycoder
    Commented Nov 6, 2023 at 20:59
  • \$\begingroup\$ would you like to recommend any books for sv synthesis? Have you authored a book on this topic? \$\endgroup\$
    – lousycoder
    Commented Nov 7, 2023 at 1:37
    \$\begingroup\$ @lousycoder, your synthesis tool should have documentation for the synthesis rules. \$\endgroup\$
    – dave_59
    Commented Nov 7, 2023 at 8:08
