I have ancient multimeter, recently the resistance range shows very incorrect values (or nothing). I have schematics and started to analyze, but can not identify how the resistance measure works.
According to my knowledge resistance measurement works in a way that voltage drop across the measured resistor is converted to resistance, for this reason path from battery+ (+9V bottom of picture) to battery - (-9V bottom of picture) via COM/V/OHM must exists (for current to flow) and for me it is not possible to identify.
For next description following switches are in opposite position than pictured on schematics:
- SA1: ON/OFF switch (in schematics OFF is painted)
- SA3: ON for resistance measurement (in schematics OFF pictured for voltage/current measurement)
- SA6: ON range selection, SA6 picked randomly as SA4 to SA9 are range switches, only one can be turned ON.
To complete explanation SA2 is AC/DC switch in position as on picture it should be in DC mode. For easier navigation in schematics the discussed paths are marked, hope correctly.
Battery +9V is connected to COM via sequence R19(2k2), VD9, VD7(diodes). Alternatively +9V can reach V/OHM via R19(2k2), R31(k1),VRD307C (selector resistances), R30 (2k)
But can not find path to -9V ?! Path for -9 is quite easy and it is connected only to negative power of the converter (MHB7106 - ancient piece of socialistic engineering) and display
To not bother with datasheet here are important pins of MHB7106 described:
- 1: Power V+ in
- 26: Power V- in
- 36: Reference V+
- 35: Reference V-
- 31: Measured V+
- 30: Measured V-
- 32: COMMON (do not fully understand this pin, as it seems like sink path on first look, but then I would assume it must be connected to -9V, but it is NOT, if I would be connected to -9V it would ruin all voltage measures, because it IS connected directly to COM.
Any ideas how to troubleshoot/repair this multimeter? My knowledge in electronics is limited, also will be happy if someone can explain what I'm doing wrong.
PS: It is easier to buy new one, but this one is present from person that means a lot for me, for this reason I would like to repair this multimeter and continue using it.
Edit: Diode KA261 has forward drop of <1v, not very precise but can not find better datasheet. That would explain the 6.4V on COM, it gets there from 9V+ via R19-VD8-VD7, but COM is connected directly to pin 30 (V- measure). Another path is R19-R31-(range selector)-R30 to V/OHM and from V/OHM via R13 to pin 31 (V+ measure)
