On the laptop's PCB I see two Schottky barrier diodes connected with reverse polarity between the Vin line and gnd. What is the purpose of this?
At first I suspected that it might be a TVS or a Zener diode, but when I looked at the datasheet, I saw that it was a Schottky barrier diode, product number (EA60QC04,) designator (PD13)
Does this serve as a simple reverse polarity protection? If it was connected in series, there would be a voltage drop and this is an undesirable situation. Was it connected in parallel for this reason it? Were using dual diodes used to dissipate heat in case of reverse polarity?
  • \$\begingroup\$ Hard to make a guess without seeing the full schematic. Could be a reverse polarity protection provided that there's a fuse of some kind on VIN+ line, or could be clamper for VIN+ line (if that's the case, looks a bit meaningless without the clampers for another positive rail), or could be a freewheeling diode of a buck converter (PR82 looks like a current sense and the rail coming from its left-hand terminal could be a feedback path) provided that VIN+ is coming from a switch (could be on-chip or external). Post the full schematic. \$\endgroup\$ Commented Nov 9, 2023 at 10:16
    \$\begingroup\$ @RohatKılıç This is a good answer. It seems doubtful to me that other possibilities would apply. \$\endgroup\$ Commented Nov 9, 2023 at 10:29
Those aren't diodes for general protection as much as they are for keeping PL9 and the VIN+ connector out of trouble when VIN+ gets disconnected, by providing a short-time alternative current path.
  • \$\begingroup\$ "alternative current path" can you explain this? I couldn't imagine what kind of alternative path there was. \$\endgroup\$
    – Electronx
    Commented Nov 9, 2023 at 10:03
    \$\begingroup\$ Alternative to current flowing from a connected VIN+. Inductors do not react gracefully to abrupt current changes. The diodes will then source a small amount of charge from the ground that will end up on the capacitors. \$\endgroup\$
    – user107063
    Commented Nov 9, 2023 at 11:15
These are flyback diodes that shunt inductive kick-back. A good idea whenever there is inductive filtering on the load and/or the parasitic inductances combined with high load cause concern.
