I am using Altium 2023. I have designed a PCB layout and now want to change location of some components based on DXF file from SolidWorks. But when I import a DXF file on a mechanical layer, then I can't select all components and move them on top of my existing PCB layout so that I can precisely update the position of some components. Any thoughts why it's happening?
Anytime I've added 3D models to Altium layouts I've done it by adding it to individual components' mechanical layers, not the .pcb file's mechanical layer
  • \$\begingroup\$ Can you elaborate it? DXF file does not add 3D models. I am issue with working on DXF files \$\endgroup\$ Nov 9, 2023 at 14:46
