I'm developing an embedded systems project (I'm quite new to the area) and I have determined that I want to use the CC430F5137, my problem is: How can I develop for it?
From cross-compilation, to driver software, to: USB -> JTAG, JTAG -> Programmer and programmer to the MCU itself. Are these the normal steps in the process?
Can a CC430F5137 be programmed with a generic MSP430 programmer? I realize this is more than one question, but mainly I would like to know how I can develop for TI's CC430F5137 MCU.
I'm seeing Spy Bi-Wire next to JTAG on the datasheet. This 2-wire (plus power and ground) programming/debugging interface means you don't even need a JTAG programmer : the low cost Launchpad or EZ340 boards or EZ-430 RF2500 can program the processor, for $5 or $10.
Not all MSP430 CPUs have Spy-Bi-Wire, but according to the datasheet you are lucky; this one does.
I use MSP-gcc (actually MSP430-Ada as an alternative to c) for program development, and mspdebug with either of the above programmers.
  • \$\begingroup\$ Thank you, I found Launchpad just before I read this, I'm buying it because it's so cheap and great for prototyping. Can I use the programmers you mentioned to program more than one CC430F5137? Is the MCU detachable, so I can flash the my binary to any number of MCU's? \$\endgroup\$ May 13, 2013 at 20:28
  • \$\begingroup\$ The MCU on the Launchpad is socketed but it's only in a 20-pin socket. The way you use the Launchpad with your own CPU (which is in a 48-pin package) is via a 4-wire cable (or 4 separate wires!) to a connector (or pins!) on your own PCB. \$\endgroup\$
    – user16324
    May 13, 2013 at 20:57
To get started, you probably will want a development board, like CC430F5137 Wireless Development Tool, which has a JTAG interface. Studying its schematic and the datasheet, you should be able to design your own board.
Then you can use a programmer like the MSP-FET430UIF (from what I read in its datasheet, the CC430F5137 is supported), using a development environment like Code Composer.
