12
I am making a cable to connect two boards as shown in the image below:
board image
The cable will be around 25 cm long and will be in an electrically noisy environment (consider 220 VAC house wiring lines touching it physically). Cable will have a PVC sleeve on top. Both boards will be in a non-earthed plastic housing. One of the boards will have an ac-DC PSU circuit that generates 5V 1A.
The cable carries the following signals: GND, 5 V (1 A max), UART (3.3 V, 9600 baud) Tx and Rx, three relay signals (signals are 3.3 V logic and meant to drive the transistor that in turn will drive the relay).
I need some help understanding what would be the right cable design for this application. The below image shows my current idea:
wire spec
My questions are as follows:
  1. Do I need the mylar + aluminium foil shield? Is that going to help me?
  2. If I use the foil shield, should I connect it to GND signal.
  3. If I am using the shield, is the above drawing optimal? Or should I do separate shielding for any signal as well? For ex - [UART tx and rx in a shiled] + [All remaining signals]. And then another shield to cover this combination. Ultimately both shields will touch but there will be a shield foil between UART and other signals.
  4. Is 28 AWG copper wire conductor good enough for 5 V, 1 A power? Or do I need to use a thicker wire?
    \$\begingroup\$ 5. How much voltage drop can you tolerate? \$\endgroup\$
    – winny
    Commented Nov 14, 2023 at 12:59
    \$\begingroup\$ In calculating you voltage drop, remember to use the out and back length, so 50 cm in your case. If you can tolerate the voltage drop, 28 AWG copper should be OK. \$\endgroup\$
    – SteveSh
    Commented Nov 14, 2023 at 13:17
    \$\begingroup\$ Pre-certification only applies to compliance with the Zigbee standard, not to EMC and radio testing. \$\endgroup\$
    – Lundin
    Commented Nov 14, 2023 at 15:21
  • 10
    \$\begingroup\$ The first diagram looks like it was drawn by MC Escher. \$\endgroup\$
    – Theodore
    Commented Nov 14, 2023 at 22:26
    \$\begingroup\$ Not to contradict the experts, but I wonder if perhaps people are overthinking this. It's a ~10 inch cable carrying low-speed digital signals, and the only outside interference is some nearby house wiring. Unless I missed something, it's not clear from the question and comments that this is a commercial product at all, much less something with stringent requirements for EMC. I would be surprised if there are any problems. If you're worried, add a checksum to your UART messages (which you're probably doing anyway) and call it a day. This is not a harsh environment for electronics. \$\endgroup\$
    – Adam Haun
    Commented Nov 14, 2023 at 22:38
4 Answers 4
10
Ed note: bahaha, I discovered the 30,000 character limit for a single answer. It seems I need to split this off. Well, just as well; it's a more direct answer to the question. Please see my other answer for the detail underlying this answer.
Summary
To sum up the points above, I can -- at last -- answer the questions as written:
If I use the foil shield, should I connect it to GND signal?
Need, no. Assuming you can add adequate filtering on both ends of each connection (typically an ESD clamp diode at each connector, say 100R in series at the transmitter pin, and 1k to the receiver pin with 1nF at the pin to GND), logic level serial at this baud rate will be more than adequate.
You can connect it if you like, which has the effect of raising the K factors in the equivalent circuit. Performance is limited by the quality of the screen/shield itself, and how well terminated it is at both ends: for typical screened cable, you can't get the screen wire any closer than say an inch to the board, and you'd have to use EMI gasket tape and some hackery to do better. This short uncoupled length (cable wires loose in air between shield and PCB) allows voltage drop along the shield wire and therefore CM-DM mode conversion. Given the likely frequencies here, it would still offer some improvement. But clearly -- assuming adequate filtering is possible, it's not at all a necessary improvement, so don't sweat leaving it open, either.
If I am using the shield, is the above drawing optimal? Or should I do separate shielding for any signal as well? For example, [UART TX and RX in a shield] + [all remaining signals]. And then another shield to cover this combination. Ultimately both shields will touch but there will be a shield foil between UART and other signals.
Not necessary; as long as signal output rate is low enough (this is a question of emissions and signal quality, incidentally), compared to length of the cable, it doesn't matter how they are shielded. (Again, shieldless is acceptable given filtering, so it really doesn't matter what happens here, lol.)
If they were high-rate signals, individual shielding -- basically making an array of coax cables -- would be desirable. The second-best and I guess most common substitute for this, is ribbon cable with every other wire grounded: the interleaved grounds prevent signals from "seeing" each other directly, keeping coupling between them low enough to pass digital signals with adequate fidelity (<10% signal bounce, say). Ribbon cable of course is unshielded, so suffers the same concern as above (CM-DM mode conversion), and would still need to be filtered; if you were doing, say, 10Mbps SPI between boards, I think I would want to see RS-422 in use, even over such a short distance. That, or a shielded cable, with the shield braid terminated to the board ground plane via metallic connector, or with the jacket stripped back a ways to fit a ground clip.
A final comment about shielding, by the way; it should be grounded at both ends. Leaving one end open, means any common-mode voltage on one board, is not carried through the shield as shield current, but carried on the signals within, and thus CM-DM mode conversion ensues, and wailing and gnashing of teeth. This is the number one mistake on USB (another fully shielded signaling standard), which is repeated disturbingly often, and yet erroneously; there are almost no applications (read: perhaps some % of all total?) where shield is not hard grounded to the PCB. The most often quoted contraindication for grounding shield at both ends, is ground loop; but clearly that cannot apply here (only one board has another connection at all, let alone grounding), and, obviously, opening the shield allows precisely that ground-loop voltage into the signals within, destroying signal quality. It's a non-solution; the correct solution for ground loop is an isolated interface, not a cut shield.
Also mind that, through all of this, "ground" refers to local circuit ground or reference plane. Safety ground, earth, has absolutely nothing to do with AC/RF grounding, and indeed galvanic and EMC grounding can be done independently of each other, given a clever enough interface (namely, bypass caps and CMCs). There is certainly no reason evident in this question, to make a safety ground connection; or at most one (near the power supply, to sink its ground-leakage current; this would in fact be required if it is of BASIC type insulation, but hopefully it is REINFORCED type and the output can be grounded or floating without any issue).
At this length, that's not too bad. It's thinner than I would specify on a new design, but I would accept it if needed for other reasons (thin cable?).
You may want thicker cable anyway, just because it's handy; multiconductor of 22AWG or so is quite abundant.
Or... well, maybe that's the thing, you're cutting up a USB cable or something, I have no idea. :)
Since this is an engineering site, I feel obliged to call out that this design is fundamentally flawed: you cannot have plain 3.3V UART signals across a wire which is exposed to heavy EMI. It is an entirely unsuitable bus to ever leave the PCB, let alone to use in noisy environments.
Shields, ferrites etc are just desperate last minute attempts to patch up a design which should never have been made in the first place. You should use RS422/RS485 transceivers, period. They also are approximately 100 times cheaper than 1m shielded cable.
Furthermore, 5V 1A AWG28 isn't promising either, depending on cable length. You have to consider voltage drop over copper wire at high currents. At 25cm it shouldn't be a problem, but there's a reason why 24V supply and 24V logic levels for relays etc is the industry standard - it's a design with margins.
This thread is kind of case-in-point why I would like to discourage questions on EMC here; the format of this site is not well suited to topics of such complexity.
But as these questions inevitably continue, and as I inevitably draw myself into them... I ought to provide an in-depth explanation here.
I think it important readers understand why I say this. The Stack format is rigid: one question, few quick answers, upvote ranking. Only the most minimal peer review occurs by upvotes, comments, and rarely, edits (and flags to moderators in extreme cases). This format discourages complex topics, that either require considerable background information to cover meaningfully, or require ongoing conversation to sort out a user's confusions.
So, I'm engaging in writing this answer, knowing not just its length, but the delay introduced by disclaimers or meta like this, have the unfortunate effect of greatly reducing the readability, reviewability, popularity, whatever, of it. Still, I consider this a necessary sacrifice.
Newbies, probably, cannot conceive of just how complex and encompassing EMC topics are; this has certainly been my experience with the topic here (but, that's still only dozens of occasions, hardly a general sampling). But it's not limited to newbies; even among seasoned veterans, largely they work within only a limited subset of the entire topic. As a result, we often make incorrect extrapolations to work outside of that set. It is truly an exceptional case, when one works with such diversity of applications, often enough, and builds and maintains a deep understanding of them, that one can truly be considered an expert; these are very few indeed, and so we justifiably celebrate such authors as Henry Ott, who has literally written the book on Electromagnetic Compatibility Engineering.
In the interest of openness, disclosing bias, blind spots -- for my part, I mostly work with commercial designs. If you hand me a design to review, without any specifications, I will assume levels typical of say EN 55024 (unless it's patently obvious it should be something else). I would say I have a strong understanding of EM waves and fields, how they move around impedance networks (circuits, cables and systems), etc. I am proud to say I've brought over a dozen products through testing, with none or only minor changes required to the design (e.g. add ferrite bead here or there), that did not necessitate a re-test. (That includes cases where I made a major revision to an existing, failing design, which passed in one revision from me, obviously not counting revisions before I was involved.)
Anyway, to explain this topic, first: an introduction to testing.
EMC Testing
These tests won't, in general, be equivalent to real scenarios, especially if your exact scenario happens to be well defined (EUT installation, wiring situation, aggressors and victims all known); but they are designed broad enough that, anything which passes the set of tests, is likely to succeed in practice; and, anything that fails in practice, has a good chance of accusing the aggressor of fault (i.e. some other equipment is violating its emissions levels) rather than itself (susceptibility failure). And if nothing else, most equipment must simply tolerate impaired operation; unless you're willing to pay for it (i.e. something important, like life-support equipment), reliability simply doesn't (or shouldn't!) need to be so strict that momentary interruptions are unacceptable. Such is the basis of, for example, US FCC Part 15 compliance; the FCC recommends, but does not require, immunity testing, and devices simply must "tolerate" harmful emissions in their environment.
Definitions:
EUT (Equipment Under Test)
EMC (Electro-Magnetic Compatibility)
  1. Conducted
    RF energy is applied to the system directly, via coupling networks. A LISN (Line Impedance Stabilization Network) is used to couple directly to the mains port. Wired data pairs or other ancillary connections use a CDN (Coupling-Decoupling Network). Other cables use an injection clamp, including fixed cables between units of the EUT, if long enough (typically ≥3m).
    Typical levels: 3V RMS (unmodulated), 80% AM (1kHz), 150kHz to 80MHz. Example method: IEC 61000-4-6.
  2. Radiated
    RF energy is applied to the system via radiation from an antenna, in a suitable (usually semi- or fully-anechoic) chamber. The EUT is set up in specified manner (elevated on a metal or insulating table, cables dressed, connections to ancillary equipment terminated with ISNs or CDNs, etc.). Both linear polarization directions are tested, and field strength is checked in front of the EUT.
    These tests (conducted and radiated) simulate the effect of malfunctioning equipment (erroneous emissions) and nearby radio transmissions (presumably, licensed users: handheld devices, portable and fixed transmitters, radio towers, etc.). Spot checks can also be performed at specific frequencies, such as ISM bands (where higher emissions are permitted for unlicensed users).
    Typical levels: 3V/m RMS (unmodulated), 80% AM (1kHz), 80 to 1000MHz. Example method: IEC 61000-4-3.
  3. Electrical Fast Transients (EFT) and Electrostatic Discharge (ESD)
    I'm lumping these together merely for their waveform similarities, and effects on the circuit; the actual test methods are actually quite different.
    EFT is applied via coupling network or capacitive cable clamp. The waveform is, as the name suggests, a fast pulse: 5ns rise, 50ns width, 50Ω source impedance. This is fast enough that the wave energy physically "washes over" the system, at (near-)light speed, and reflections off cables and modules are visible on the oscilloscope trace. Because of the transient and cable-guided nature of this test, impedances remain comparable, and so we expect similar impedances where these waves crash into EUT interfaces, like logic pin clamping diodes (1kV / 50Ω = 20A, these are intense pulses; not for long, but it doesn't take much time at this power level to fry a microcircuit!).
    ESD is a more practical, day-to-day sort of situation: sparks are applied to any exposed metal, any part of the surface where a spark can jump, and to coupling planes placed around the EUT such that the resulting EMP (Electro-Magnetic Pulse) can affect the EUT (emulating the effect of striking a metal table, a nearby filing cabinet, etc.). As the switching event is a spark in air, the rise time can be impressively fast: under a nanosecond. Needless to say, this wavefront washes over the system, radiating outward in space, carried upon wires and metal surfaces and bouncing off them. From my own testing, a slot type gap in an enclosure, subject to direct ESD in the middle of the slot, passes significant energy (enough to disrupt digital signaling on boards within the enclosure) for a slot length of just a couple inches -- that is, the slot looks like an inductive path, around which ESD current must flow, and some energy therefore can pass inside via this route. The peak current from direct contact can be over 30A, again a tremendous input for microcircuitry. And with many kV behind it, this is simply not something you can insulate away; it must be shunted around the circuit.
    Pulse rate: ESD pulses tend to be single, infrequent events (1s+ between). EFT typically has a burst distribution, which emulates the discharge of inductive loads (solenoids, transformers, motors, etc.) across opening mechanical contacts. Typically the repeat rate is 5 or 100kHz, 75 pulses per burst, and 300ms burst repeat rate. This makes EFT uniquely capable of knocking out digital communications, for example by corrupting a packet, the subsequent retransmission packet, and so on. Robust error detection, correction and mitigation methods are therefore valuable additions to the protocol.
    Typical test levels and methods: ESD: 4/8kV (contact/air discharge), IEC 61000-4-2; EFT: 0.5kV, IEC 61000-4-4.
  4. Surge
    Surge is a larger, slower waveform, used on applicable ports, typically long-distance connections such as mains power, and telecom cables, that are subject to induced or direct lightning surge, and transients due to inductive switching and line faulting. Typical rise times are a few µs, duration 10s µs to ms, peak voltages up to a few kV, and source impedances of a few to several tens of ohms.
    Typical test levels: 8/20µs, 1.2/50µs "combined wave generator" (rise time / half-amplitude pulse width), 2Ω source impedance, 1kV differential (mains line-to-line), 2kV common mode (line to GND). Typical method: IEC 61000-4-5.
Among these tests, we can ignore surge to some extent, as the equipment is (presumably) isolated from hazardous mains voltage, and no other long-distance connection is specified. The power supply itself still needs to be tested for mains surge, but assuming it passes these tests (typically an off-the-shelf unit is chosen, carrying such ratings, among other useful features), no further consideration is required.
That leaves the fast-transient and modulated-CW tests to pass.
Equivalent Circuit
According to the description and comments (at time of writing), the system is composed of:
  1. A mains input connection
  2. One PCB containing an MCU and unstated other circuitry
  3. A cable to another board, carrying power, serial comm signals and unstated (logic level?) signals
  4. Another board with HMI elements, presumably another MCU to provide the HMI-to-serial interface, and an RF module (and perhaps the module provides the programmable MCU too).
Relays are mentioned, but it's not clear what purpose they serve, if any; certainly there is no need for isolated contacts when there are no other connections made to the board. If they are, in fact, connecting to switched mains circuits for example, that would be critical information, absent from the question, with likely major consequences for this analysis. I will assume for now that the relays connect to nothing, or only low voltages within the circuit, so can be ignored, as with other components within the local ground plane.
Given this description, we can create an approximate equivalent circuit for EMC purposes.
We will choose a LISN to represent the mains connection, and assume the system would be tested on elevated ground plane, thus giving a modest and consistent CM impedance for cables with respect to the plane, and some lumped-equivalent capacitance of the two modules with respect to the plane.
This might be drawn as follows:
enter image description here Source: own work; available on website: Two Board EMI Equivalent.png | Seven Transistor Labs
The input/mains filter is left as a skeleton, as only the broad strokes are relevant: some CM impedance provided by a CMC (this being the most common arrangement), and some isolation impedance provided by the transformer and a 'Y' type capacitor. The low-voltage supply is not shown, but implied between 3.3V1 and GND1.
All signals in the cable are not shown; only two, GND and TXD, are highlighted for purposes of simplification. Without loss of generality, similar circumstances can be applied to all. Note that, assuming VCC is bypassed at both ends, that wire acts in parallel with GND, providing a rudimentary shield around neighboring wires; this effect is implemented by the coupling factors K between the inductances.
Notice there are many assumptions here already, and many more simplifications. A ground plane has been assumed for both PCBs. This is a matter not just of convention, but fundamental sanity: without a plane, traces are subject to the free fields around them, and the whole analysis is sausage. That is, it would no longer be meaningful to speak in terms of supply or signal voltages, with respect to an implied reference ground plane; all voltages between any given points in the circuit, would depend upon the path of the measurement itself (in general, voltages between points in a field are dependent on the exact size and shape of the measurement loop). Put another way, the voltage measured between different points in the circuit, even those notionally equal (the GND net, the connected (galvanic) circuit between pins assigned as such). That is, there would be voltage, in general, between points within a given net, true for any net onboard.
It is possible to construct effective designs without planes, or with fewer than recommended layers; the challenge however increases exponentially, as one must account for both local and ambient fields swirling around all connections, and filtering RFI, clamping ESD, etc. all become far less well-defined -- and less effective.
Thus, the GND1 net, here, implies the whole ground plane of the PCB, and if you like, 3.3V1 is the supernode related thereto by adequate supply bypassing. Likewise for GND2 and 3.3V2 on the second board.
This leaves the point of interest, and the subject of the question: what to do with the cable between boards?
Immunity, Signaling, Filtering
Let us apply the various standards to the circuit as given:
  1. Conducted: only the mains port applies. This is represented by V2. There are no other external connections to terminate or excite.
    The equivalent circuit is of the system having some stray impedance to ground, which therefore draws some current from the conducted source (at the LISN), and consequently drops some voltage along the impedances between sections, particularly the between-boards cable.
    The voltage drop along the cable, depends on the relative impedances around it, and its own. Note that a voltage drop between boards, is not an automatic failure: there is, however, some CM-DM mode conversion, which needs to be accounted for. That is, the current flowing on the GND/VCC wires, is not also flowing on the signal wires (as it would in a true differential circuit), and therefore not all the voltage drop (between boards) gets applied to the signal lines. This is evident in the equivalent circuit, for example because TDX1 has a resistive source impedance, and TXD2 a high load impedance (gate input pin), while the GNDs are hard-tied to both PCB planes.
  2. Radiated: we can employ some hand-waving here. At lower frequencies, the linear structure of this system looks like a 1/4 wave antenna, common at the mains LISN, with two modest loading capacitors along its length. (Incidentally, the mains cable equivalent is not shown; we can roll it into L4's overall impedance, for the most part.) To the extent that L4's impedance dominates over cable impedance, we can also consider it a break in the line (in which case the two boards and comm cable look like an end-loaded resonator). The mechanism of coupling will be mutual inductance, primarily around the base of this structure (i.e. the mains cable); and mutual capacitance, primarily around the PCBs and connecting cable.
    At high frequencies (wavelengths comparable to the cable electrical lengths), we cannot use a lumped-equivalent model to express the cables, and a transmission line model takes over. The mains cable equivalent remains a wildcard, as does L4 (typically, CMCs have falling impedance above a few MHz, but the impedance in the 10s or 100s of MHz may peak up or down erratically). We can at least note that the mains cable has a modest ballpark CM impedance (for a typical two-conductor cable elevated 50mm above the plane, this will be around 150Ω), and is terminated into a 25Ω LISN (both channels acting in parallel, V2 = 0), so should have a maximum Q factor around 150/25 = 6. Thus we do not expect mains cable resonances to be any stronger or peaker (narrow) than this factor.
    The two-boards-and-cable structure acting as an end-loaded dipole resonator, manifests at frequencies where that structure represents about a half wavelength. Since the cable is 25cm, the wavelength will be around 50cm or 600MHz; this is something of an upper limit, whereas the two PCBs act as lumped capacitors against the cable's inductance, lowering resonance. I would guess somewhere in the 300-600MHz range, sensitivity is highest.
    There will be subsequent peaks and valleys above this frequency, and also corresponding to dimensional scales such as the board length/widths, exact lay of the cables, trace or patch antenna modes on the PCBs themselves, etc.; but these will largely be at high enough frequencies we don't need to worry about them, at least at a first pass. (Depending on standards used, immunity beyond 1GHz may be required, perhaps even including harmonics of the radio module -- so, up to low 10s of GHz. These are such high frequencies that they aren't meaningful to consider in terms of conduction along cables, and whole-board shielding is basically the only effective mitigation. Boards are generally not very sensitive up here -- the attenuation between free fields and thin traces over ground plane, is pretty reasonable for commercial applications and test levels -- but if necessary, shielding of any sort, from absorbent materials, to metal cans, or milled enclosures, can be applied, depending on severity and budget.)
  3. EFT and ESD: these are somewhat of a hybrid case, in terms of analysis; the edge rates are fast enough to consider the mains cable at least (well, most likely?), and EFT maybe not so much the connecting cable, but ESD most likely so, as transmission line equivalents rather than LC lumped equivalents.
    Note that, because the connecting cable is less than 3m, it most likely does not need to be tested by itself with use of a capacitive clamp coupler. Thus, V3 = 0, and we only need consider direct mains-conducted transients, and ESD anywhere exposed metal can be struck.
    Given the defined setting, we might still opt to set up a more detailed/specialized environment, mimicking the nearby mains wiring. We could, for example, set up a "dummy" cable, that is unpowered, terminated into ISNs at both ends, and excited with EFT from one or the other end (preferably, test both), and against which the EUT is positioned in a representative manner. Such testing will not be found in the most common, general standards, but can be constructed by agreement between a supplier and customer (typically only when such contracts constitute enough value to specify and test to such detail -- mains distribution switching equipment, and railway equipment, are two such examples that come to mind).
    Given the impedances in circuit (largely the ratio of cable CM to DM mismatch), and the rapid rates of these waveforms, we expect considerable peak current and/or voltage to appear at the transmitter and receiver of these signal lines.
    There is a strong advantage to the topology, however: because one board is "flapping in the breeze", its CM voltage can ride up to whatever at modest time scales (corresponding to frequencies ≪100MHz, say) without drawing excessive current in response to that voltage, as it would if it were hard grounded for example. As a result, these pulses are differentiated (high-passed), to some extent; the outcome is a strongly reduced energy dissipation required of the circuit, versus EFT or ESD being dumped hard into a pin directly.
The important take-aways here are the ratio of impedances, and the frequency ranges over which we expect concerns. At frequencies proportionally lower, we expect proportionally higher immunity (voltage or current). If due to cable/board resonance, we expect a tolerance of less than 1V (or 1V/m, roughly speaking) at 300-600MHz, we expect a tolerance of perhaps 10V at 30MHz, and so on. With a 3.3V logic level and 3V or 3V/m testing, this suggests we should only have problems at high frequencies.
Another take-away, that might not be so obvious from the above, but supports it greatly: only use the bandwidth you need! 9600 baud is a 104µs pulse time, which only needs as much analog bandwidth to convey; we might still maintain a good 30-100kHz analog bandwidth just to preserve a cleaner waveform. (This arises as a tradeoff between UART timing recovery, MCU pin input noise immunity (that is, the filtered analog signal with respect to the pin receiver itself), and how the UART samples the waveform -- typically three samples taken from the middle of a pulse, where a pulse is 8 or 16 sample periods long.)
The required 100kHz bandwidth, is hugely below the range of concern (10s MHz), making this a trivial slam-dunk strategy to ensure clean data.
Might it even be enough margin to pass EFT or even ESD without data corruption?
We can simulate these situations and take a look.
Simulation
For modeling purposes, I'm representing L4 as a 100Ω resistor. This is probably on the pessimistic side, but also doesn't capture any peaks or valleys a real part (plus the mains cable we're implicitly rolling into it) might have. Parts aren't documented to such frequencies anyway, nor are they consistent (the peaks and valleys vary from part to part, due to manufacturing tolerances), so this is a compromise solution.
I'm also changing the cable CM model, from capacitance to a reference plane, to a resistor from each capacitor pair (C1, C7; C2, C8; C3, C9) to ground. Let's say 10Ω each. This is a bit of an on-the-fly change, I apologize, but it is justified because we need some representation of radiation losses at these frequencies; meanwhile, there is no longer a need to illustrate the capacitive clamp.
Without any load at the receiver side (an assumed linear open-circuit pin), the TXD2-GND2 voltage is about 170V:
Adding a BAV99 clamp diode and local 3.3V supply, a much more modest value results; notice the signal is disrupted for about a hundred nanoseconds, then returns to its intended (low) value. (Without loss of generality, the same will be true for a high state, at least within variance -- the pin driver's output impedance will be slightly higher most likely, that's about it.)
Mind, this is with R1 in place, implying a linear output resistance; in practice, the output pin driver will clamp to its body diodes, reducing the peak at TXD1-GND1. This doesn't have much effect on the result at TXD2.
Applying a 1k + 1nF RC filter, we get ample analog bandwidth (~160kHz), modest attenuation at HF (it's only a single-pole filter), and -- a completely clean signal:
TXD3 is the added RC node (not shown on the above schematic, another running modification I apologize for). Peak is well below the typical CMOS input pin threshold of 30% VCC or 1V. This is at 1kV EFT (applied via NEUT); presumably this could be about five times worse or 5kV and still adequate, which brings us up to ESD levels (4/8kV), perhaps with moderate interruption of service (bit errors once in a while); a simple error detecting and re-transmitting protocol would seem adequate, or if it's a regularly-sampled HMI thing, you might simply not care that a packet is erroneous once in a while, thus delaying its reception by one sample period. (If you're transmitting only changes e.g. in LEDs or pushbuttons, you might want to use a CRC in the packet, followed by a simple ACK response or such, to ensure errors can be detected and packets retransmitted. Otherwise, continuously re-transmitting fixed levels, with a CRC or whatever to detect errors, should be simple and effective.)
As for AC response, this is approximately the conducted sweep. Albeit to much higher frequencies, for which a radiated model should apply.
This is normalized to 0dB at NEUT input (not counting its self-impedance, hence the lumpy trace at top), and at least gives the jist of what to expect. Note the sensitivity due to CM-DM mode conversion competing with isolation capacitance, peaking around 50-60MHz; and the extra blips up around 150-200MHz, corresponding to cable resonances (evidently, the values I picked are a bit "long", modeling closer to a 1m length cable; this is all very approximate, just for show, not a real worked problem). Even accounting for other coupling methods (better representing a radiated mode), it's clear the attenuation to the receiver pin, with filtering, will be highly effective.
Other Signaling Standards
Notice that, to this point, I haven't even mentioned other signaling standards, like RS-232 or -422 (let alone protocols like CAN)! The noise margin of these is much wider, owing to higher voltage levels* or differential mode operation, and they can be used in conditions like these without filtering (at least for immunity purposes), while also offering capabilities like multi-drop, multi-master, bidirectional communication (half-duplex or time-division multiplex) on a single pair, etc.
*RS-232 is a funny one, because in its original embodiment, it might be 12, 15, even 20V or more at the transmitter's supply -- bipolar (±15V or whatever), so that the receiver could have a threshold near GND while offering a large noise margin (>10V) in either state. It's been diluted over the years (and, frankly, isn't very relevant anymore anyway; we're quite happy these days to use differential pairs, on more elaborate, robust and flexible networks, like CANbus for example), so that a MAX232 clone that operates on 3.3V, might only deliver ±6V output -- leaving a noise margin hardly higher than the logic-level signals driving it. It's still an improvement, granted -- and 6V is greater than 3V (or 3V/m, for hand-waving V/m ≈ V), so it's not like it's useless out of the gate. But in such typical modern use, it is merely a shadow of its former self. Anyway, not that it was ever widly flexible or anything: the pin states are fixed so you can't make a multi-drop bus, and the slew rate and output current are limited so that it can't go very fast (120kbps or so).
I haven't mentioned the media either, simply assuming the worst case (multiconductor cable, no shield/screen).
But we can apply similar analyses to these, and draw similar likely conclusions:
  • RS-232 will pass conducted and radiated, and may fail transients without filtering
  • RS-422/485 will pass conducted and radiated, and may fail transients without filtering
  • Differential pairs require additional wires in the cable, adding cost
  • Shielding (assuming adequate bonding to PCB grounds on both sides) can be used to assure, any of these really, will pass all tests
A cost analysis might justify the use of one or another kind of cable, or what interface to apply. For my part, I would be more than happy using ESD clamp diodes on both ends, a small source-termination resistor on the transmitter end, some RFI filtering at the transmitter, and an RC filter at the receiver end (maybe an RLC filter too, a ferrite bead on the line then a small cap at the clamp diodes to get more RFI immunity).
A similar filtering/protection scheme would be desirable for any signaling standard regardless; and obviously, differential will need more filter components. Granted that clamp diodes may be assumed provided with the interfaces, if their ESD ratings are adequate (8/15kV levels are often provided for robust automotive or industrial use), but this can be a dubious course of action as you need to know whether the devices will recover automatically from ESD strike, or require a power cycle to resume normal operation.
Note that it's not adequate to use oversimplified filtering schemes; for example, an RS-485 transceiver, in receive mode, filtered by only a common-mode choke (CMC), sees little if any attenuation of common-mode noise because its input impedance (small capacitance || high resistance) drops little voltage across the CMC. Some CM loading is necessary. For point-to-point links (such as this), the termination resistor can have its midpoint bypassed to GND, then offering excellent CM immunity. This is not permissible in multi-drop links, for which at most, some mild amount of capacitance can be introduced, and only as a significant compromise to baud rate and distance limits of the network. (A CMC does still offer transmit-mode CM filtering, which can be a strong benefit for emissions.)
Summary continues here: https://electronics.stackexchange.com/a/689139/311631
    \$\begingroup\$ Please try and keep it to one post and be succinct \$\endgroup\$
    – Voltage Spike
    Commented Nov 15, 2023 at 0:40
    \$\begingroup\$ If you could suggest some points to trim I would welcome a critical voice. \$\endgroup\$ Commented Nov 15, 2023 at 1:45
  • 4
    \$\begingroup\$ @TimWilliams - Thank you so much for putting so much time and energy into this beautifully written answer. I have been on this website for many years and had a great experience in general. I have learned a lot, sometimes by asking questions, sometimes just by browsing the site. However, there are times when I feel surprised and extremely happy to see the generosity of people around here. This answer is one of those moments for me. My sincere thanks to you for the effort you have put into helping me and potentially many other newbies who will come across this answer in the future. \$\endgroup\$ Commented Nov 15, 2023 at 4:20
  • \$\begingroup\$ @TimWilliams This is an excellent answer, useful to many; may I suggest putting this in its complete form (unhindered by 30k char limits) on your website. Cheers. \$\endgroup\$ Commented Dec 3, 2023 at 5:57
6
  1. Depends. A shield introduces a capacitance across the cable and itself. This extra capacitance may or may not cause a problem on bit rise and fall times. In your case, the baud rate is low, 9.6 kBaud so the minimum pulse width is ~100 μs. So, rise/fall times of up to ~20 μs could be acceptable (in theory), assuming the receiver samples the incoming signal at mid pulse. But if your overall circuit and PCB design (layout) is so bad the rise and fall times are way beyond these acceptable values then even the best shielding techniques wouldn't save you. So yeah, it depends on a few factors. In late 90s (maybe even before) the RS232 cables we used with PCs and external equipment were shielded but the amplitudes were higher (i.e.5V and above). So, although the wires are relatively short in your application, maybe you should consider level translation i.e. 5V running on cables but the transmitter and receiver still uses 3~3.3V. Doesn't have to those expensive level translator ICs. A single-transistor translator for both RX and TX would work.
  2. I prefer connecting the shield to GND at one end only (source-side) to prevent current flow through it.
  3. This relates to "1" above.
  4. You can check the average wire resistance (per 1000 ft or per km) then calculate the drop. As SteveSh pointed out in his comment, the total drop will be twice the wire resistance per ft the wire length in your application can be approximated to 1 ft times the total current. This webpage states a resistance of ~65 Ohms per 1000 ft, so ~65 mOhms per wire in your case. If we ignore connection resistance (i.e. wire to board and vice versa) the drop across each wire will be ~65 mV. So 5V, when the current drawn is 1 Amp, will be seen as 5 - 0.065 x 2 = 4.87 V. Now it's you who could say if this amount of drop is acceptable or not as you know the application and components.
EDIT: Both UART receivers are ARM cortex M0 microcontrollers from Nuvoton. Nothing special. Just Tx and Rx connected. If this means exposing the MCU inputs to outside world directly then I'd think twice.
  • \$\begingroup\$ Capacitance is a non-sequitur; the characteristic impedance simply is whatever it is, with or without. If it's low, a lower pin driver impedance could be used; but given that generous filtering should be employed here, pin and Zo impedance will both be superseded, and the 25cm cable amounts to a lumped equivalent a tiny fraction of overall filter capacitance. || GND (and VCC) are connected between boards already, likely hard-[AC-]grounded to the boards at either end; recommending one side grounded shield is almost certainly actively harmful. \$\endgroup\$ Commented Nov 14, 2023 at 14:49
  • \$\begingroup\$ @TimWilliams Capacitance is a non-sequitur how? The standard defines the maximum load capacitance (2.5 nF max) which includes the cable capacitance as well so why/how could the cable-shield or wire-shield capacitance be unrelated? As for shielding on one sides or both side, it depends on the application. Neither bonding at one end nor both ends is the absolute correct way. \$\endgroup\$ Commented Nov 14, 2023 at 15:12
  • \$\begingroup\$ Isn't the question "should I connect it to ground signal or to (main) Earth"? Since EMI will come mainly from main lines nearby. \$\endgroup\$
    – Fredled
  • \$\begingroup\$ @RohatKılıç Length is specified; at typical capacity of say 60pF/m, it amounts to all of 15pF/conductor. I'm not aware of any single-ended signaling standards using plain logic levels (whether 3.3V or 5V; not to say they don't exist, they're just not commonly referenced as such), but if you mean RS-232, I would gladly filter much heavier than nominal-max, as the specified baud rate is quite low. And quite some series resistance can be added, because of the short length. \$\endgroup\$ Commented Nov 14, 2023 at 15:23
    \$\begingroup\$ With a 25 cm (~1 ft) cable and rise and fall times of ~10 us (for a 9600 baud link) this is just simple lumped circuit - no transmission line effects. So we're only really concerned with the total equivalent lumped circuit capacitance. So just filter the heck out of the signals on the receiving end, just keeping in mind the input transition time requirement of the receiver. \$\endgroup\$
    – SteveSh
    Commented Nov 14, 2023 at 20:28
