I've have been trying to make a current to voltage converter using a transimpedance amplifier circuit. I have been simulating the circuit in LTspice and everything seems fine, but when I built the circuit in real life it has shown a problem I don't understand.
The circuit is as follows:
The problem is that in the simulation and as expected, the node at the inverting input of U4 is around 100 uV. In reality it is measured at around 900 - 1100 mV depending on the current source. First the current was controlled via a voltage source and a resistor, then I tried with a Howland current source and now the inverting input node is at 2.4 V.
Shouldn't the node be at virtual ground since the non-inverting input is grounded?
I would like for the output to be in the interval 0-3.3 V for currents in the range of -300 - 300 uA.
Note: I'm currently using a TL072 opamp instead of the LM324.
  • \$\begingroup\$ What about the negative supply voltage V2? Why didn´t you use it? \$\endgroup\$
    – LvW
    Nov 16, 2023 at 10:21
  • \$\begingroup\$ V2 or V- is being used to offset the inverting input and to supply other OP-amps beside this circuit. \$\endgroup\$ Nov 16, 2023 at 10:23
  • \$\begingroup\$ My recommendation: Try a symmetrical supply for the opamps. \$\endgroup\$
    – LvW
    Nov 16, 2023 at 10:26
    \$\begingroup\$ Please note that the LM324 can sink its output pin to the negative rail. I think the TL072 is not able to do the same. \$\endgroup\$
    – hennep
  • \$\begingroup\$ The minimum output voltage of the TL072 is above 1.5V. That would explain the 900-1100mV on the inverting input. It is caused by feedback from the output pin through R5 \$\endgroup\$
    – hennep
    Nov 16, 2023 at 10:43
Shouldn't the node be at virtual ground since the positive input is grounded?
This would happen if the op-amp was provided with a negative supply voltage. Currently it is using ground as the negative rail and this won't permit the op-amp's output to go to a negative voltage (and restore the virtual ground condition).
On the other hand, try reversing the current direction from \$I_1\$ and, you will see it now works reasonably well (with an LM324).
That will happen with \$I_1\$ reversed.
In that case you will need a negative supply rail because the common-mode input range of that op-amp does not include the negative power rail
