Im designing a bruched motor driver unit that controlled with a mcu (stm32f410) and H-Bridge driver (DRV8243S). im using AOZ2261NQI-12 to supply H-Bridge driver.
The IC supplied with 24V (polarization guaranteed by a smart diode and mosfet).
I couldnt get any reasonable output. PGOOD pin always gives LO. When I activate the EN pin, the output is at millivolt level.
Something is wrong with device configuration. AOZ2261NQI-12 device configuration
Or I give damage while soldering. 310C heat gun, till to melt solder (Sn62, Pb36, Ag2)
    \$\begingroup\$ Which solder bridge at MODE pin is shorted? \$\endgroup\$ Nov 18, 2023 at 13:56
  • \$\begingroup\$ SB5, forced to PWM. But also I tried other option. Nothing changed \$\endgroup\$ Nov 18, 2023 at 15:27
  • \$\begingroup\$ Then try with VCC = 5V. \$\endgroup\$ Nov 18, 2023 at 18:39
The IC can't work with VCC = 3.3V because UVLO threshold for rising VCC can be as high as 4.5V. Apply 5V to VCC pin.
The datasheet recommends VCC = 5V which is the voltage that the IC is characterised at.
Also make sure the correct solder bridge is shorted i.e. mode is selected.
