At first is sampled data from the IMP23ABSU MEMS mic converted to V by multiplying each sample by the conversion factor \$ \frac{1}{32786} \$. Then i want to calculate the FFT and PSD after applying a passband with 20-80kHz range and windowing. Since im working with a lot of samples (around 17.538.000) it seems only right to represent the data in logarithmic scale. For that im in need of converting the data into dBV.
The mic has a sensitivity of -38 dBV ±1 dB @ 94 dBSPL, 1 kHz. If i convert the sensitivity to V i get a correction factor of 0.012589 by calculating \$corr_V=10^{\frac{-38}{20}}\$. How can i convert the data now to dBV using this correction factor? Do i just multiply each sample by the correction factor? How can i then represent the dBV correctly using the FFT?
