I'm building a keyboard which will use SK6803 mini-e LEDs (ws2812 driver). I'm using a Pi Pico and as such the USB limit for current draw is ~500mA. I'm looking to limit the current draw from the LEDs to around 300-400mA and I found out that the TPS2553DBVR IC can do this, however I'm a bit confused about the NFAULT and EN pins.
In my current design I don't have enough GPIO pins on my MCU for the EN and NFAULT signals so I was wondering if I can ignore the NFAULT, either leaving it floating or pulling it high (or low, I'm not sure tbh), and for the EN pin either just having 5V+ going in or using the same data signal which turns on the LEDs (also a 5V signal, but driven) so that the current limiter is always on? I just want it to consistently limit the current in the given range.
My schematic so far is looking like this:
Any help would be greatly appreciated!
Also if I use 5V+ for the EN pin, should I use VBUS or VSYS from my Pico, and would a pull up or down resistor make sense?
