I'm asking, because the information on Wikipedia is extremely lackluster, perhaps even incorrect.
This is my current understanding:
A 72-pin module has 12 address pins, 4 CAS, and 4 RAS pins. (For simplicity, I'm disregarding parity here). Data is 32 bit wide (4 bytes).
A read cycle consists of applying a 12-bit row-address, pulling a CAS pin high, then applying a 12-bit column-address, and pulling one of the RAS pins high.
In effect, a memory location address is 24 bit wide (12 bit for row, and 12 bit for column). So that's 2^24 = 16777216 = 16M memory locations per one combination of CAS/RAS selection.
However each module allows up to four CAS and RAS pins. Each time, only one one of each must be strobed. So one out of 4 CAS and one out of 4 RAS, giving 16 combinations.
With those, that's the 16M locations from above, times the 16 combinations of CAS/RAS strobes, resulting in 16M × 16 = 256M locations.
Since each location applies a 32-bit word on the data bus, that results in 256M × 4 byte = 1024MB (or 1GB) of capacity. That's the theoretical maximum capacity I understand is possible.
On the Wikipedia page, it's however mentioned that only a maximum of 128MB was ever possible (32M locations).
I don't understand how they arrive at that conclusion, but that aside, I wonder if there's something wrong with the way I understand addressing. I am aware, that smaller modules either disregarded the MSBs of some of the address pins, or used only two RAS pins, but that doesn't answer the question for the theoretical maximum. I'm also aware, that many mainboards didn't support modules larger than 128MB (or even 64MB). As another reference I used the datasheet for one of those modules made by Micron Technology Inc.
