How could I find Thevenin's voltage in this circuit?
electronic circuit diagram
I can't use KVL since i don't know the voltage rise of the current source after removing the load.
  • \$\begingroup\$ Where is this problem from? You are correct in identifying Vth as undefined. Perhaps you made a mistake simplifying a more complex circuit? \$\endgroup\$
    – vir
    Nov 25, 2023 at 19:13
  • \$\begingroup\$ @vir I just started learning circuit analysis yesterday, i designed a random circuit in falstad to test myself \$\endgroup\$ Nov 25, 2023 at 19:17
  • \$\begingroup\$ An open-circuited current source has undefined terminal voltage, just as a short-circuited voltage source has undefined current. \$\endgroup\$
    – vir
    Nov 25, 2023 at 19:19
  • \$\begingroup\$ @vir Would it be possible to further simplify this circuit? \$\endgroup\$ Nov 25, 2023 at 19:23
  • \$\begingroup\$ Not meaningfully, in my opinion, since the circuit behavior is undefined as it is presently constructed. \$\endgroup\$
    – vir
    Nov 25, 2023 at 19:27
In comments you asked,
You can further simplify this circuit by removing the voltage source and resistor, leaving just the current source. Any elements in series with an ideal current source have no effect on the behavior of the circuit.
So, back to your main question,
You cannot. This circuit behaves exactly like an ideal current source, and therefore it does not have a Thevenin equivalent.
Note: I am ignoring the ground symbol in your schematic, assuming it is only there to make the Falstad simulator happy. If it is an intentional part of the design then you can not form a thevenin equivalent for this circuit because it is not a 1-port network --- the ground symbol gives a third connection point that might affect any external circuit that also has a ground symbol.
  • \$\begingroup\$ I only used that ground symbol to mark a reference point for voltages, it's not meant as a part of the circuit. \$\endgroup\$ Nov 25, 2023 at 19:54
