I come back to ask for the help of the community in order to identify a device which was given to me several years ago by an electronics component dealer. This time I know something more, precisely
- it seems a PNP transistor since it appears as a two junction device with a common terminal which leads to a N-doped regions (it may be a double diode, but in this case it would be extremely uncommon device),
- the (gold plated) base terminal is the center one (see pictures below),
- the (gold plated) body, including the mounting screw, is isolated from the terminals
- the producer is ST Microelectronics (i.e. SGS-Thomson) (see pictures below),
- the body is marked with the following alphanumerical codes: 520400501C and 8828 (between these codes lies the ST logo) (again, see pictures below).
What I'd like to know: a data sheet would be perfect (as usual) but even a summary of the basic characteristics will suffice.
For explanation and completeness I add the following pictures of the device.
