Recently I purchased a SATA to USB adapter. To be able to access 2.5-inch (laptop) and 3.5-inch (desktop) hard drives.
Box
To my surprise, there is a board to do the conversion.
Board
USB socket
Question
Why there should be a board to do the conversion? Why the conversion process is so complex that a board is required?
Update
As pointed out by @Justme the above device has a USB socket problem. A proper device-side USB socket would look like a well-designed external HDD:
External HDD
Device-side USB
  • 5
    \$\begingroup\$ I'm curious - what we're you expecting to see there instead? \$\endgroup\$
    – brhans
    Commented Dec 1, 2023 at 12:26
Yes, without going to details, it's complex, and it's because USB and SATA are completely different protocols, intended for completely different applications. They use different electrical signaling, different line coding, different packet structure, everything.
You need a chip that can do the conversion.
The chip needs to be placed somewhere, and it needs connections to USB connector and power supply connector, and internally to SATA connector.
The chip, connectors, and components that do the required power supply conversion are best done with a PCB.
Also, it is clearly a poor quality design. They did not even bother to put the correct USB connector there.
They put a host-side socket to a device that should obviously have a device side socket. You now possess a possibly dangerous USB cable which allows you to make connections between devices that you are not supposed to make and can damage the devices.
  • \$\begingroup\$ Thanks for your answer. I don't see the chip. Probably it's on the other side of the board. So, it's hidden from my eye. \$\endgroup\$
    – Megidd
    Commented Dec 1, 2023 at 11:59
  • \$\begingroup\$ @Megidd Those are not questions related to electrical engineering, so suggesting what consumer products to buy and from where are off topic here. \$\endgroup\$
    – Justme
    Commented Dec 1, 2023 at 13:10
