I have never seen a relay depicted as below:
From SYL-2342 Datasheet from here (pdf)
Can someone explain what is going on for terminals 6, 7, and 8?
Terminal 7 is the common point between a normally closed contact (terminal 6) and a normally open contact (terminal 8).
When the device is not powered, terminals 6 and 7 are connected. When the device activates terminals 6 and 7 open and terminals 7 and 8 close.
Pins 6, 7 and 8 are a set of SPDT contacts. Pin 7 is the common, Pin 6 is the normally-closed contact, and pin 8 is the normally-open contact.
