I have a 40mm fan with a connector that has standard breadboard pin spacing. I would like to connect it to what I thought was a relatively standard fan connector that has wider spacing (and thicker pins).
In the image below, the fan is wired to the connector on top; I'd like to connect it to the connector on the bottom:
What is the name of the larger connector? That would make it easier to find an appropriate adapter.
  • \$\begingroup\$ Is the pitch 3.96 mm by any chance? \$\endgroup\$
    – Hearth
    Dec 4, 2023 at 4:15
  • \$\begingroup\$ Seems like it could be, sure. \$\endgroup\$
    – larsks
    Dec 4, 2023 at 4:25
  • \$\begingroup\$ Or 5/32" (~0.156") pitch, for those wondering why the designer didn't just choose 4 mm. \$\endgroup\$
    – Graham Nye
    Dec 4, 2023 at 14:01
They are both: single-wall wire-to-board connectors. But ...
Note: even if you have the matching plug, that doesn't mean that it will work. We don't know whether the PCB male header is intended for a fan, and, if it is, what its pinout and signaling is.
    \$\begingroup\$ Thanks, that looks like a great reference! We do know that the PCB male header is intended for a fan, and we also know the pinout of the connector matches the fan. \$\endgroup\$
    – larsks
    Dec 4, 2023 at 13:34
