We manufacture fireproof power plugs for high-voltage transformers used in mines. The way it works is we take the incoming single-phase cable and epoxy it into the plug and attach it to the transformer. However, we want a way to show that the cable is live.
The idea is to insert an LED into the plug that will light up when the cable is live. Do you guys know of a way we can power it remotely without connecting to a source? Perhaps by the electromagnetic field produced around the cable?
The problem we have is guys remove/steal the earthing protection in the mines and then blow up the transformer when they remove a live cable. If the cable had an LED to show it was live the guys would not remove the cable and risk blowing themselves up. This is purely to improve the safety of the plugs and save lives. We install them in African mines where I am from.
Any advice or guidance would be greatly appreciated. I did a mechatronics course while doing my honours in Mechanical Engineering so hopefully that helps.
