I am struggling to tune in the RG_on and RG_off values of gate resistors for SiC MOSFET. I have tried a lot to tune in the values but at turn off transition there is persistence high frequency ringing which at low switching currents are not causing any huge impact but as soon as I switch high power, it causes false turn on as magnitude of that ringing is very close to threshold voltage of SiC MOSFET. Anyone can recommend any good literature? I read few papers but the strategy they have written either I am unable to understand or its not applicable on my case. Thank you
\$\begingroup\$ What is your gate driver? Are you driving the gate negative to turn it off, as is usually recommended for SiC parts? \$\endgroup\$– HearthCommented Dec 5, 2023 at 16:31
1\$\begingroup\$ I would probably design a snubber circuit to address the ringing and help you filter out that behavior. What is your design here? Perhaps you should probably resort to the datasheet of your FET and look at the frequency responses as you set parameters for RG. \$\endgroup\$– user319168Commented Dec 5, 2023 at 17:06
\$\begingroup\$ It sounds like your issue is something beyond a mere gate resistor. What have you determined about the switching loop, particularly stray inductance? \$\endgroup\$– Tim WilliamsCommented Dec 5, 2023 at 17:24
1\$\begingroup\$ Please provide you PCB layout \$\endgroup\$– John BirckheadCommented Dec 6, 2023 at 3:13
\$\begingroup\$ @Hearth I have added my schematic and result for your reference. I am noy using negative turn off voltage infact i am turning off at 0V \$\endgroup\$– AlisonCommented Dec 6, 2023 at 7:47
Show 4 more comments
