Basically I'm trying to feed in High low signals into the TX pin of a HM-10 BLE module and display it as a graph, similar to how an oscilloscope would, or possibly just have a threshold where it would change some indicator on a web app. Chrome allows you to use bluetooth if you type in
chrome://flags/#enable-experimental-web-platform-features
to the search bar and enable it, and applications exist to connect to them such as
https://loginov-rocks.github.io/Web-Bluetooth-Terminal/
https://github.com/ErniW/Web-Bluetooth-and-HM-10-module-for-Arduino
but they seem to be more focused on sending messages rather than raw 1 and 0 voltage input.
So.. How would one go about just receiving the data?
Thank you for your time and help if you can share some wisdom.
... but you don't send voltage levels by Bluetooth... you send bytes \$\endgroup\$
