I'm analyzing the OpenBCI Ganglion board and I reasoned that switches SW1 through SW4 (part number CJS1200) might in fact be useless. The negative input for each channel (X_IN-) is connected via a 330K resistor to a buffer (INPUT CURRENT BIAS, bottom left of the schematic), the switches let the user choose if they want to send the amplifier the real X_IN- or REF, which is connected to the same buffer via a 330K resistor.
Couldn't the exact same thing be accomplished by leaving the negative input disconnected?
If the negative inputs really need to be connected together (for reasons I have yet to understand), could the job be done by simple ON/OFF switches connecting them to a common rail itself connected to the buffer via a 330K resistor? In this way we would avoid the signal degradation caused by the switch if we are interested in using the differential input. Complete schematic
We're missing some context here since you've only showed us one page of the schematic. I would like to see where REF and IN_X- are coming from. But if I had to guess, I would say that the SW1-4 are NOT "useless" as they could be changing the mode of the AD8237 operational amplifiers and could greatly influence the gains of the amplifiers.
  • \$\begingroup\$ REF is connected to the op-amp buffer named INPUT CURRENT BIAS in the bottom left corner, X_IN- refers to an electrode connected to the patient. \$\endgroup\$ Dec 6, 2023 at 6:20
