I have a 555 in monostable mode that will generate a signal from the transition to low from one of it's inputs (as they do). The issue I have is that the trigger will out last the signal by an order of magnitude and I need it to only trigger once.
What kind of circuit can I use to produce the result I want with the 555?
Image courtesy of: https://wavedrom.com/editor.html
Original Question:
I have a sensor that will loiter low before going high, stay there for a relatively long while then repeat. My trigger is the transition from from high to low. This allows me to use my 555 in monostable mode to signal for a short time. However the trigger will remain low even after the signaling time. I'm only looking to trigger the signal once in triggers sensor's cycle.
Right now my hammer is the 555, and I've thought about trying to resolve the problem with another in bistable mode, but then I just have another trigger on transition issue.
I'm looking for insight into how this may typically be handled, with a 555 or not.
