This question is most probably about pin-configurations registers. I mean since QSPI is the same as SPI with more data bus-width (correct me if I'm wrong on this first assumption), then doesn't it mean that some pins can be configured to act as a QSPI peripheral?
It seems like a simple(?) DIY tweak to be able to implement QSPI communication by allocating/configuring a few more pins, and of course make/change things in the code, based on what a proper QSPI communication demands.
right?
