12
I spend almost all my tinkering time with 1970s era logic circuits, which use almost all original 7400-series TTL. I do a fair bit of repair and am now starting to design additional logic to work with old circuits, and I am a little fuzzy on the risks/rewards of using (say) 74LS series parts in these designs, either as substitute/replacements or in new parts of a circuit.
The chart on this page indicates that the 74yy00 variants largely vary across propagation delay and power consumption:
My sense is that the LS variants are generally appropriate to substitute for the basic versions, with the general caveats that:
  1. An existing circuit design might implicitly rely on certain propagation delays and that using parts with faster timing could alter the behavior undesirably.
  2. I guess you could use more power than expected if you swap in just the S variant instead of LS?
Are there other, more functional or more concerning reasons to beware of intermixing, or specific other things to watch out for?
I want to not be foolish about these variants in old circuits but at the same time if a 74LS04 works just as well as a 7404, they're certainly cheaper and easier to find (and some of the logic chips never existed in the basic version, only in LS, etc.) AS and ALS (per the chart) look even better to me if I'm not sensitive to propagation delay, but again, I don't want to be blind about it.
  • 4
    \$\begingroup\$ Bear in mind that any answer to this question will not apply to the currently-easier-to-get 74HC and 74HCT chips--even though the HCT series has compatible logic levels, its drastically different output stage could cause issues. I'm not sure about LS vs original in this regard, which is why this is a comment and not an answer. \$\endgroup\$
    – Hearth
    Commented Dec 10, 2023 at 21:39
    \$\begingroup\$ @Hearth. Thanks for that. When you say drastically different output stage, what does that mean in this context, and how might it interact? \$\endgroup\$
    – BZo
    Commented Dec 10, 2023 at 22:18
  • 5
    \$\begingroup\$ The original 74 series, as well as the S, LS, AS, and ALS series, have limited output drive strength--you can actually drive an LED straight from an output without any current-limiting resistor. The HC, AHC, HCT, AHCT, LVC, ALVC, and AUP series have much stronger output drive, and if put into a design that relied on that limited drive strength you can kill some chips. \$\endgroup\$
    – Hearth
    Commented Dec 10, 2023 at 22:43
  • 4
    \$\begingroup\$ The speed of later designs (output slew rate, not delay) can also induce ringing and crosstalk issues in poorly laid out boards. \$\endgroup\$
    – Hearth
    Commented Dec 10, 2023 at 22:46
  • \$\begingroup\$ You want to investigate the logic thresholds and sink and source currents to determine more accurately what you might find in a basic fan-out comparison table. This is especially true if you shift to CMOS versions with more equal sink-source. Also static electricity damage thresholds differ. The 4000 series CMOS devices have different pinouts sometimes. At low speeds logic is very forgiving. \$\endgroup\$
    – KalleMP
    Commented Dec 11, 2023 at 9:46
4 Answers 4
8
In general, it's usually safe to mix 74xx logic families, with the following potential pitfalls:
  • The TTL-based 74 series have logic levels concentrated around the low end of the supply voltage, while the CMOS ones (other than the xxT CMOS series) have logic levels spread more completely throughout the supply range. This means that a 74LS driving a 74HC, for instance, might not be able to drive the HC's input to a point that would read as high. The converse is not true; a 74HC output can easily drive a 74LS input with no issues. To compensate for this, the CMOS-based 74HCT (and other xxT designations) are specifically designed to have TTL input levels, and can be driven directly from TTL outputs.
  • The output stage of the 74, 74S, 74AS, 74LS, and 74ALS series uses a resistive pull-up, meaning that they can safely drive an LED, BJT base, or similar load directly from the output without current-limiting. The output stage of the CMOS-based 74C, 74HC, 74AHC, 74HCT, 74AHCT, 74LVC, 74LVCT, and 74AUP series uses an active pull-up, and attempting to drive an LED-like load directly from the output will break either the load or the logic chip.
  • Some of the more recent series might be too fast. By this I don't mean in terms of input to output delay (though that can also cause problems), but in terms of output slew rate. PCBs laid out with original 7400 chips in mind might encounter crosstalk or ringing issues from the very fast edges of 74HC or other more modern parts.
  • Different logic series have different rated fanouts and different input loads. If one 74xx output is driving 10 inputs, that chip probably can't be replaced with a 74LS (which can't drive as much output load), though it would be fine to use a 74HC (which can drive significantly more output load). Back in the day, logic chips were rated in terms of how many "standard logic loads" (equivalent to one 7400 input) their outputs could drive, and how many "standard logic loads" their inputs counted as.
  • Logic oscillators rely on IC delays to work. If you swap out a 7404 being used for a ring oscillator for a 74HC04, you might find that suddenly the entire board stops working because you've drastically increased the clock frequency. While oscillators like this are very unusual today, they were common in the heyday of 74-series logic.
One potential problem with substituting LS for regular TTL is the reduced fanout.
Regular TTL can typically drive 10 TTL loads. LS TTL can typically drive 5 TTL loads (8 mA). I use 'typically' here to refer to the guaranteed drive of a typical output (ie. excluding buffers and such like with higher output drive than normal).
Of course timing could be an issue if the circuit is pushing the limits (or is badly designed). Many older circuits used questionable asychronous techniques or even pressed the parts into some kind of linear-type operation such as oscillators. In that case, substituting types may well lead to interesting issues. Much faster parts may require better layout and bypassing than slower parts.
There are some designs where exact type of the chip may be required, as envisioned by the circuit designer:
  • I have seen a 8 MHz oscillator consisting of three NAND gates connected in a closed circle, without any additional elements. It would obviously work at different frequency if the gates have more or less delay, or maybe not even at all.
  • I have seen 5V voltage stabiliser where a single NAND gate that produces the reference voltage. I actually made such a stabiliser, and it worked fully OK at least at stable room temperature.
  • Oscillators and Schmidt triggers consisting of the two gates connected sequentially (and indirectly in ring with positive feedback) were also quite common, almost standard. The required values of the additional discrete elements likely depend on the electronics inside the gates.
  • Level indicators, flipping the gate from 0 to 1 at the threshold input voltage. Multiple gates were often connected sequentially to steepen the response.
  • Also, some otherwise truly digital circuits are unusually loaded (like driving LEDs or powerful transistors). If the chip is rated for the lower maximal output current, it may not pull out.
    \$\begingroup\$ I don't know how prevalent the first three examples were, but even 40 (or more) years ago they were considered bad design practices. The main reason being is that they made use of non-guaranteed or even non-characterized parameters (such as the analog gain through the witching region) for their operation. \$\endgroup\$
    – SteveSh
    Commented Dec 11, 2023 at 15:15
    \$\begingroup\$ I realise that's probably a typo, but it does paint a picture! \$\endgroup\$ Commented Dec 11, 2023 at 20:32
  • \$\begingroup\$ @JasenСлаваУкраїні - it was (and still is) black magic... \$\endgroup\$
    – Jon Custer
    Commented Dec 12, 2023 at 14:15
One of the references I was thinking about in my comment is TI's Logic Guide, sdyu001ab from 2017. This is available on TI's web site, and provides a lot of good information on the compatibility of various logic families. Some of old S (AMD) and FAST (Fairchild) documents from the 80's have similar information.
Here are a couple of snippets from the TI document:
