In general, how can you tell?
As a specific example, how would I know from looking at the following datasheet? http://www.alps.com/products/WebObjects/catalog.woa/E/HTML/Potentiometer/RotaryPotentiometers/RK09K/RK09K1130AV7.html
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIn general, how can you tell?
The relationship between the angle of the knob and the resistance is the "taper". That datasheet says this pot's taper is "1B".
Finding information on what 1B means is a bit tricky. It's at the related information link at the top. The tapers are described at the very bottom. Here's the relevant image:
It's hard to read, but 1B is the straight line in the upper-left. This is an ordinary linear pot.
This is something of an industry convention. See for example Alpha's pot tapers. By convention, anything with a "B" in it is a linear taper. Anything with "A" in it is "audio" or "logarithmic".
