What is this connector type?
It is on a Christmas LED chain. It should be IP67.
  • \$\begingroup\$ I think on bigclive's YouTube channel he noted that while these connectors are mostly used for low voltage (12 - 24v), he had found some that were used for 240v! So check the actual voltage you need because a connector type doesn't necessarily dictate voltage and wiring patterns. \$\endgroup\$
    – Eilon
    Dec 11, 2023 at 20:15
Maybe this help you find the manufacturer of the connector: https://www.luminalpark.com/en-eu/4m-vintage-led-36v-extension-clable/58491 and https://www.luminalpark.com/en-eu/blog/pml-connector-change-from-ip44-to-ip67
I used google images to search the image you provide.
    \$\begingroup\$ Links may go stale, so it helps adding some more text about how you came up with those links to start with and possibly a summary of your findings. \$\endgroup\$
    – user107063
    Dec 11, 2023 at 13:25
