I am trying to do a power assessment of a microcontroller (TMS320F28379D, datasheet link: https://www.ti.com/lit/ds/sprs880o/sprs880o.pdf?ts=1702312460730).
The output pins of the microcontroller is connected to a level-shifter IC's \$ 3.3V \$ side, for shifting to \$ 5V \$ (SN74LVC4245A, datasheet link: https://www.ti.com/lit/ds/symlink/sn74lvc4245a.pdf?ts=1702310500407).
A simple schematic is given below: enter image description here
The electrical characteristics of the microcontroller is this:
Microcontroller
And the electrical characteristics of the level shifter is this:
Level shifter IC
  1. Is the supply current (current going into \$ V_{CCB} \$) of the level-shifter \$ I_{CCB} \$ in the datasheet? Or, is \$ I_{CCB} \$ the current that all input pins will take?
  2. From an earlier question (Current into level shifter IC from microcontroller), I understood that the input pins of the level-shifter IC can take +/- 5 uA. Does this mean that the microcontroller's output (connected to the level-shifter) will also be the same?
  3. Is the +/- 4 mA (\$ I_{OH}, I_{OL} \$) mentioned in the microcontroller's datasheet just the maximum current that uC output pins can supply?
  1. \$I_{CCB}\$ is indeed the current drawn from the B-side supply. However, it is specifically the current at no load; any load on the output will increase this, because the output current has to go somewhere. Also note the quantity \$ΔI_{CCB}\$, which is the change in \$I_{CCB}\$ per high input.
  2. Yes, unless there is something else on the microcontroller's output that pulls additional current.
  3. Yes and no. It's the maximum current they are rated to supply. It may be possible to pull more current from them if you short them to ground, but this runs the risk of damaging your microcontroller and should not be done.
  • \$\begingroup\$ "per high input" - sorry if this is trivial, but what does this mean? I can see that the input pins are connected to the microcontroller whose output voltage is the V_OH and V_OL specifications (I think). \$\endgroup\$ Commented Dec 12, 2023 at 15:34
  • \$\begingroup\$ @curious_direwolf For every B-side input that reads a logic high, the B-side supply current increases by no more than \$ΔI_{CCB}\$. \$\endgroup\$
    – Hearth
    Commented Dec 12, 2023 at 15:35
  • \$\begingroup\$ The B-side inputs are going to be PWM signals (for my current application). Would it be right to say that the supply current will rise by no more than 5mA (for 10 inputs to the level-shifter B-side)? \$\endgroup\$ Commented Dec 12, 2023 at 15:39
  • \$\begingroup\$ @curious_direwolf Considering that would be ten times what the datasheet's listed maximum would imply, yes, that's a safe assumption. \$\endgroup\$
    – Hearth
    Commented Dec 12, 2023 at 15:40
  • \$\begingroup\$ Thanks! I meant 5mA instead of 50mA (I have edited the comment to reflect the same) \$\endgroup\$ Commented Dec 12, 2023 at 15:42
  1. ICCB is the supply current that the VCCB sinks. So it is the supply current for the low-side of the level-shifter. My understanding is that when all I/O pins are at either VCCB or GND, ICCB is 50uA. For every low-side pin that is at a voltage below VCCB-0.6V, ICCB increases by 0.5mA.
  2. Yes, the microcontroller will source the same amount of current that the level shifter sinks. This is only if the connection is a direct connection between the pins without any other connections that may cause the microcontroller to source more current.
  3. Yes, that is the maximum current that the pins can safely source and the minimum current that the pins can safely sink as an output.
  • \$\begingroup\$ Are the voltages to the low-side pins governed by V_OH and V_OL specification of the microcontroller? \$\endgroup\$ Commented Dec 12, 2023 at 15:57
  • \$\begingroup\$ Yes the SN chip will accept whatever voltage the microcontroller pins are outputting. \$\endgroup\$
    – InBedded16
    Commented Dec 12, 2023 at 16:09
  • \$\begingroup\$ " direct connection" - if it isnt direct, and there is some resistor pulled to ground in the connection, the V_OH/V_OL specs can be used to find the current throught that resistor right? In addition to the 5uA current, the uC will supply this current as well. \$\endgroup\$ Commented Dec 12, 2023 at 16:14
  • \$\begingroup\$ That is basically correct yes. I would recommend doing a bit of research into pull-up/down resistors if you want to understand this more. There are a lot of resources out there that will give you an in depth explanation of how these parts will play with each other and affect stuff like the voltage and current levels. \$\endgroup\$
    – InBedded16
    Commented Dec 12, 2023 at 16:17
  • \$\begingroup\$ Yes, I understood how the pull-down resistor works, but my doubt was on what the voltage that the microcontroller output pin will give if it is connected to the SN chip's input. \$\endgroup\$ Commented Dec 12, 2023 at 16:41
  1. Iccb = 50 uA is the recommended current sunk by Vccb per pin.
  2. No. Microcontroller's outputs have their own ratings. It's up to the designer verifying the electrical compatibility between the microcontroller and the level shifter.
  3. No. Output pins can give you more than that but the output voltage will drop.
Ciao
