Maybe someone can help and knows how to calculate the differential gain and common-mode gain in a differential amplifier. Will the formula for differential gain be Ad=Rc/2Re, i.e. in my case 50/40=1.25? I don't know how to calculate the total.
Can this be measured in Multisim?
Diagram with parameters in the photo.
First diagram
Second diagram in which a current source was used
  • \$\begingroup\$ Are you asking for theory and how to calculate things? If so, just simplified theory using a simple linearization around an operating point? Or large scale theory that illustrates the arctan behavior more fully? Or are you asking for a complete schematic testbed that you can use for simulation purposes in order to extract numerical values? \$\endgroup\$ Commented Dec 15, 2023 at 19:18
  • \$\begingroup\$ I would like to know what formulas to use and which values to substitute (values from the attached diagrams) to calculate it correctly. \$\endgroup\$
    – grigoriii
    Commented Dec 15, 2023 at 19:21
  • \$\begingroup\$ Please consider reading this. \$\endgroup\$ Commented Dec 15, 2023 at 19:30
  • \$\begingroup\$ V3 should be -15V \$\endgroup\$
    – user319836
    Commented Dec 16, 2023 at 0:01
  • \$\begingroup\$ Ok, You right V3 is now reversed. But my osciloscope show: image Is this correct?, or shouldn't it show a second wave. Am I missing something in the multisim? \$\endgroup\$
    – grigoriii
    Commented Dec 16, 2023 at 11:28
  • The so-called "differential gain Vd" is based on the assumption that Vin1=-Vin2. Therefore, the current increase in Q1 is identical to the current decrease in Q2. As a result, the current through the common emitter node remains constant and we can treat this node as signal ground. That means: The gain Vd (referenced to one collector output) is identical to the gain of a simple common-emitter gain stage without feedback:
    Vd=(+ -)gm*Rc (gm: transconductance; gm=Ic/Vt).
  • In case of common-mode operation in both transistors the current increase (resp. decrease) is identical. So this current increase causes a feedback voltage across the resistance in the common emitter leg (static Re, or dynamic re when there is a 3rd transistor). Without additional calculations, we can use the known gain expression for a common-emitter stage with feedback. However, because the current increase/decrease is twice that of a single transistor, the feedback resistor must be doubled in the gain formula:
    Vcm=-gm*Rc/(1+2gmRe)
    (in case of a 3rd transistor replace Re by re (large dynamic transistor ouput resistance)
  • \$\begingroup\$ OK, but i have problem with second circuit (second image), with additional power source. What values to substitute into the formula to calculate it? \$\endgroup\$
    – grigoriii
    Commented Dec 18, 2023 at 6:47
  • \$\begingroup\$ As I have mentioned in my answer: Replace Re by a "dynamic re when there is a 3rd transistor". This is the large output resistance (often called "ro") of the 3rd transistor. \$\endgroup\$
    – LvW
    Commented Dec 18, 2023 at 8:09
