I'm looking to make a car battery charger for learning purposes. I have read through this this post and this post.
While I am still confused about certain things, it seems generally agreed upon that a safe charging current is 15 to 20% of the battery's capacity. For the battery I have in front of me right now (60Ah) that would represent 9 to 12A.
I've connected the battery to a bench power supply, and getting it to 10A seems to take about 17V. This seems quite in excess of even the car's ~14.4V when turned on.
To be clear, I know that constant-current bulk charging is only meant to happen to a certain point, and that the higher voltage will damage the battery if it leads to overcharging.
So, if I'm doing constant-current charging on a lead-acid battery, should I be concerned about reaching a voltage that is too high for the battery?
