I'm doing an AND gate in a circuit using 2 transistors BC337-40. I'm also using an LED in series and a 680 Ohms resistor.
I expected the LED to light up only when both transistor bases were HIGH. But when the second transistor is short-circuited it closes the circuit with the base of Q2 and current passes from the Base to the Emitter.
How can I go around this with BJT transistors?
No way to get around the base current flowing through the terminal biased in forward direction, the emitter if not in reverse operation.
Limit the base current to sane values - TTL used almost 1 mA, if memory serves.
Design the rest of the circuit such that this base current does not impede operation of the circuit.
Here, base resistors of about 4.7 kΩ and a 680 Ω resistor from Q2 emitter to ground should do the trick.
If you place R1 in series with the LED, you even get a TTL level output, but the input will not be compatible to any 5 V logic family.
For lack of voltage amplification, such "gates" will not work in deep networks: to build a 42 input gate, you would need 6 levels at least.
