Watching this video I encountered an analysis of the following circuit:
The value of \$V_0\$ is computed as follows
As \$I=V/R\$ by Ohm's Law, we set \$V= 10V - 0.7V\$ and \$R=3k\Omega+4k\Omega\$, getting \$I = 1.33mA\$.
Again, by Ohm's Law we know \$V=IR\$. Setting \$I=1.33mA\$ and \$R=4k\Omega\$ we get \$V=5.32V\$, which is the value of \$V_0\$.
Is the reasoning correct? If the voltage at a point is to be measured in terms of the resistance in front of said point (as \$V_0\$ was measured in terms of the \$4k\Omega\$), would that not imply that measuring the voltage at a point in between the battery and the first resistor should be done as follows:
\$V=IR=(1.33mA)(3k\Omega)=4V\$
even though the voltage at that point should intuitively be \$10V\$?
