I have a portable integrity test device (BEA Technologies – Italy), model Z02030300 (X-150-N.)
The pressure sensor inside is broken. I do not know the manufacturer of the sensor.
Does anyone know a clue to find the specifications?
In the pressure sensor, I can see the text “MI-CUX5/C7CFXL”, but cannot find any info.
Please check the photos.
    \$\begingroup\$ have you contacted the manufacturer? \$\endgroup\$
    – jsotola
    Commented Dec 26, 2023 at 7:10
  • \$\begingroup\$ They did not provide technical specifications but suggested that we replace the entire board. \$\endgroup\$ Commented Dec 26, 2023 at 7:22
    \$\begingroup\$ Part looks similar to a Honeywell sensor (see link below), though most look similar, it could be a copy. Is the P/N on a paper label, any thing under that? If you knew all the specifications a similar Honeywell part may be suitable. Any repair or replacement would likely require that the unit be re-calibrated. prod-edam.honeywell.com/content/dam/honeywell-edam/sps/siot/… \$\endgroup\$
    – Nedd
    Commented Dec 26, 2023 at 10:08
  • \$\begingroup\$ Thank you a lot for you suggestion \$\endgroup\$ Commented Jan 16 at 2:10
