I have attached the image.
When power is connected to LED A, 20 mA will flow at 100R. This is not a problem. It shines brightly.
On the other hand, the output of the MAX7219 draws only 4 mA when LED B is lit. I control the MAX7219 with ESP32 and set it to shine the brightest. When I measured the current of the MAX7219's ISET resistor, it was 0.28 mA. Apparently, the MAX7219 allows 100 times more current to flow through the LED than the ISET resistor current. In other words, LED B should be able to flow 28 mA. However, only 4 mA flows and the light is dim.
Why? How can I get 20 mA to flow to LED B?
This is a question about lighting one LED with the MAX7219. It is not an 8 x 8 dot matrix.
The MAX7219 is stated to be able to flow up to 40 mA per segment.
When connected as shown in the attached photo, a maximum of 40 mA should be able to flow through one LED. However, when I measure it, only 4 mA flows. If I use the <MD_MAX72xx.h> library, will only 4 mA flow?
#include <MD_MAX72xx.h> library is used to light only one LED at maximum brightness.
void setup() {
Serial.begin(9600);
mx.begin();
mx.control(0, MD_MAX72XX::INTENSITY, 15);
mx.setColumn(0, 0, 0b10000000);
This connects pins 9 and 13 of 1088AS to MAX7219, and only the bottom right one of 1088AS lights up. In the photo, LED B is connected to GND and pin 9, and 4 mA flows. Similarly, if LED B is connected to pins 9 and 13, 4 mA will flow.
Even though the maximum brightness is set to 15, the intervals between pulse outputs are wide. In other words, LEDs don't shine brightly. Why are the pulse intervals so wide?
the issue might be in the code controlling the MAX7219 - the datasheet containsOn initial power-up, all control registers are reset, the display is blanked, and the MAX7219/MAX7221 enter shutdown mode. Program the display driver prior to display use. Otherwise, it will initially be set to scan one digit, it will not decode data in the data registers, and the intensity register will be set to its minimum value.
. Can you edit the question to include the code running in the controlling ESP32. \$\endgroup\$
