I am designing a battery current shunt monitor that measures current while discharging and also charging. I am planning on using the INA828 amplifier feeding an ADC.
My questions revolve around the Ref pin connection of the INA and whether I need a +/- supply?
On attached diagram, in lower right corner are my two questions;
- Do I need +/- supply to the INA to measure the +/- input differential voltage in both directions?
- Do I need to provide an offset voltage to the Ref pin of the INA to convert the +/-50mV input to 0 - 2.048V output? (The delta-sigma ADC has internal 2.048V Ref that I intend to use during ADC conversion). The ADC sampling rate will be 20hz (10k+ oversampling ratio) with Sinc4 digital filter.
The shunt is not pushed hard. It's a 500A shunt. +150A is the max charging current available. -300A is the max load current that can reasonably be realized. The INA gain is chosen for shunt full range. This is a low side shunt.
I know there is a bunch to consider beyond my two questions. For now, the two questions are where I am currently stuck.
