I have a BG 2212 DC motor.
It has 6 pin connector. I tried to connect gnd and the + connector to a 20V/24V power supply but the motor did not spin at all.
It reads in the page you posted, with power supplies provided but no control signal the motor stands sill.
So it works exactly like the manual says.
The datasheet says you need to provide pin 4 with either a 0-10VDC control signal or a 10V PWM signal. If the pin is left unconnected, the motor will not run.
You can make a 0-10V signal with a potentiometer and I'd probably use an op-amp voltage follower since it doesn't say how much current it takes. The PWM signal can be provided from any square wave source (Arduino, 555, etc). If you just want the motor to run at full speed, then apply 10V to pin 4.
electrical interfaces
section in the second picture ... what does it tell you to do? \$\endgroup\$
