Although I can understand both of the diagrams above, I am confused about the relations between them.
As marked in the per-phase equivalent circuit of a 3-phase induction motor above, we assume the 3-phase value is the vector sum of three per-phase equivalent circuits separated by 120 degree phase position.
Then according to the vector sum of three separated per-phase equivalent circuits:
  • the red arrow current signal = Ids (which is the magneting current from stator for the rotor to build magnetic field)?
  • Iexc = Iqs (which is the stator magnetic field current)?
  • Finally the cross product of Ids x Iqs is proportional to the torque output?
If it doesn't, how to match the equivalent circuit currents to the vector control dq currents?
Generally speaking, the torque output is proportional do the active current (Iq) and flux is proportional to the reactive current (Id). You have to consider the machine model in both d and q frames separately. Please see source link below.
MODEL OF A THREE-PHASE INDUCTION MOTOR
