Introduction
I try to make more sense of safety and reliability of grounded and isolated electricity. I divided the problem into 3 stages:
- Power-transmission line
- Household electricity
- Electrical appliances
From my understanding high-voltage transmission lines are isolated with over-head earth ground that acts like a lightning rod. The three phases are floating relative to earth ground (3 hot phases).
Before going to household, the electricity passes a 3-phase step-down transformer which introduces a common neutral wire (cold) which is connected to a ground rod at the transformer.
Then at the household, we have line and neutral which is selected from one of the phases, then we have a ground therminal that connects to the ground rod at the house. In some country, neutral also connected to ground at the consumer unit.
As compliance should be safe to touch or shock-proof, the metal case of appliance must be connected to earth ground to ensure that electric potential always equals to ground and human body.
Neutral should be connected to ground at the transformer's location because if not, the lightning might pass through the AC wire to appliances' ground potential. With neutral connected to earth, this lightning can bypass to ground at the transformer without much damage to appliances.
In my country's standard, neutral must connect to the earth therminal to make a high-current return path in case that the line voltage leaks to appliances' metal casing so the breaker can trip.
Question
If an isolated system is power or more reliable, why can't we just make a household's system isolated by disconnecting neutral from earth ground? Will it work the same way as isolated power?
*note: I've edited the question to be more focused, the question is only on but it required some explanation in each cases.
Reference
- Application of isolation transformer in biomedical devices.
isolated ground
means something else than what you may think ... it means that the ground pin of the plug is not connected to the conduit at the power outlet ... it is connected to ground only at the breaker panel ... it is still grounded \$\endgroup\$
