This is the photo of the power distribution panel inside industrial building. On the left most, next to the two thick wires colored yellow/green so as it is likely to be the "ground" we see a strange looking device connected between the two copper rods. There are two more blue wires more on the right. Deciding from color and letter N, the blue wires are connected to the horizontal rod that is "neutral".
Hence deciding from labeling and cables, the device seems connecting neutral and ground in the distribution box that I would expect to be directly connected here. However the device appears more complex than just a simple rod. Why does it appear more mechanically complex? I assume the complexity is somehow related to its less than trivial electric functionality.
